Cold Air Intake
#31
I'm still intrigued by this, too. I don't care about any potential power increase, it's just about improving the induction noise for me.
Interesting that they cap off the sound symposer. That sounds counterintuitive.
#32
https://www.autoevolution.com/news/2...ys-124593.html
Does the Touring still have the sound symposer?
I think adding it back to the AFE would be as simple as drilling and installing a plastic bulkhead fitting onto the airbox.
#33
As per some Youtube reviews the GT3 Touring is louder inside than the regular GT3. I have to wonder if it is because of the different dual cone airbox? AFAIK that is the only difference engine wise. Cone filter intakes usually make a throaty sound.
GT cars do not have the sound symposer, we instead have a 9000RPM scream!!! I bet the duel cone BMC filters make more intake noise over the standard airbox. If you look at the AFRE instructions, I think it has a hose for the sound symposer.
The standard 991 airbox kit goes for under $600, guess how much the GT3 touring airbox kit is? It's $1800!!
Totally agreed. I meant it more to highlight that the dual cone intake thing has potential as both Porsche and they looked to that design to increase power on cars that came with our airbox. For $850 this thing might actually be good for a few horsepower and easily reversible. Might sound cool too.
The dyno chart they post looks legit... yes the car had headers for both runs which I don’t.
I’ve had a couple AFE intakes on cars in the past and I was happy with them. Nice quality. This is a little less exotic than I would like for a Porsche but at same time you couldn’t see it if you tried.
This is the Dundon manufactured intake
https://www.dundonmotorsports.com/pr...-center-plenum
The AFE kit looks legit. It has 2 huge filters, is a totally sealed box, that appears to be much larger than stock, and uses the OEM cold air ducts. Heat soak is a real thing on the GT cars, that center muffler is right under the airbox, and that area gets real hot! I have felt the top of the ducts and they have been HOT on my car. The AFE box should have less heat soak, due to the large box, the filters being faster away from the edges.
Truly, I'm surprised that they AFE unit is not on a bunch of 991's already, it looks like one of the best aftermarket options.
AdamSanta85 (11-05-2020)
#34
Thank you @Stealth 993 great info. Happy to hear the GT3 do not have the symposer.
AFE includes a cap for the sound hose, so they delete it as well.
I am excited... my order is placed...going to be a long wait.
If you look at the AFE instructions, I think it has a hose for the sound symposer.
#35
I wonder if the sound will be different between the CF and plastic version.
In my E46 M3 days, a lot of people chased after the CF airbox because the sound resonates differently in the CF material to give the CSL airbox it's rumble and roar. The consensus was that a plastic version would not produce the same level of intoxicating induction noise.
With that said, if the plastic version makes the car sound better without any power loss or drivability, that's a win in my book. People paying thousands of dollars for an exhaust just for better noise, why not also for induction noise (which I believe to sound better than exhaust noise).
Count me as an interested party -- especially at $800.
#36
I would consider doing before and after dyno to see what it does. My car is basically stock (muffler)
https://afepower.com/afe-power-54-83...-intake-system
#37
From what I was able to find out, the only real difference is the back cover is CF and the rest is the same plastic. While the CF might sound different, it will be very slight if any perceived sound.
The CF box does come with BOTH filter types, and the dust covers. To me, there is more value in that over the CF back plate.
#38
Well, I might just do the all-plastic, too. I'd go with the dry filters just because I already have their dry filter and cleaner for my Golf R.
Now, to convince my wife.
#39
So now that I am looking even further, this is an old trick at Porsche... they did the same thing for the 997's. They had flat air filters, then for the 4.0 they made a better dual cone airbox (that costs a million dollars)
https://www.suncoastparts.com/product/RS40AI.html
Then Dundon made their own and got some power out of it
https://www.dundonmotorsports.com/pr...n-fiber-airbox
#40
One other thought. For those of us who have had the heat shield recall / retrofit completed - would it impede installation of this airbox?
#42
$7k for an airbox is, just WOW!
#44
The problem is the heat shield is riveted in place so I imagine it's not the easiest thing to remove now.
