PSE vacuum hose installation diy instructions?
Old Jan 4, 2017 | 05:26 PM
jkfuel's Avatar
jkfuel
Default PSE vacuum hose installation diy instructions?
The vacuum hose is rather loose, does anyone have instructions on routing?
Old Jan 4, 2017 | 06:06 PM
Code's Avatar
Code
Check this thread out: https://rennlist.com/forums/991/8190...on-a-991s.html
Old Jan 4, 2017 | 06:23 PM
bittrl1000's Avatar
bittrl1000
Originally Posted by Code
Most of those pics are from when I did the upgrade on my car last summer. I never found detailed instructions on how to run the vacuum lines. But I'm pretty sure I did it correctly, since I found a bunch of different sources that showed various parts (One source was pausing a Youtube video showing the assembly of a 991).
And my car has worked great the last 6 months! PM me if you have any questions. I'll try to help.
Old Jan 4, 2017 | 06:28 PM
jkfuel's Avatar
jkfuel
Thanks for the links and the help!
Old Jan 4, 2017 | 07:50 PM
bittrl1000's Avatar
bittrl1000
https://youtu.be/iV0vtS2ADEI
This video gives a few very brief glimpses of the vacuum lines on a PSE, particularly around 1:55.
Old Jan 4, 2017 | 08:23 PM
Code's Avatar
Code
Originally Posted by jkfuel
Thanks for the links and the help! I'm planning on doing the pse switch/ AWE all at the same time so is a great start!
I was curious, what video are you referring to?
Do you have an S model car? and did you get the non-PSE AWE system? If so, you can use the instructions for the vac lines that come with the AWE, and since since the car already has vac lines run its a breeze. If it's a non-S car then its a whole different ball game. I too just did the non-PSE car to AWE system on my Carrera S. The console install took me 10 mins, and Porsche charged me $154 to program the button. Below is a vid of my car driving after the install in case you're interested. Good luck and enjoy!
Old Jan 4, 2017 | 08:31 PM
bittrl1000's Avatar
bittrl1000
Do you have an S model car with sport chrono?
How is having sport chrono relevant?
Old Jan 4, 2017 | 08:34 PM
plenum's Avatar
plenum
I have a S non-PSE and am looking to upgrade to PSE.
Does anyone have the PSE installation instructions? I'm mainly interested in where the vacuum hoses will go if someone has a schematic. I will be having my dealer program the console of course.
Yes. Is this what you DM'd me about?
Old Jan 4, 2017 | 09:48 PM
jkfuel's Avatar
jkfuel
Great deal- I have a 4S non-PSE car and am looking to do exactly that, the AWE w/PSE exhaust plus the PSE switch. Just for reference, it does have Sport Chrono.
Old Jan 4, 2017 | 10:06 PM
Homeles's Avatar
Homeles
If u have a "S", it doesn't matter. All the lines r there. If u want a parts list, to install an AWE system, pm me and I'll send it to u.
Old Jan 4, 2017 | 11:07 PM
Code's Avatar
Code
It's isn't, my apologies. I'm not sure why I included that in my comment.
Old Jan 4, 2017 | 11:25 PM
plenum's Avatar
plenum
Having an S configured car does put the vacuum lines in place, but when adding PSE additional hose is required and routed a bit differently through the engine carrier. You might get by with re-routing to the AWE valves, but just to be safe you should order-up some of the vacuum hose and cli;s. IMHO
Old Jan 4, 2017 | 11:30 PM
bittrl1000's Avatar
bittrl1000
No additional plastic vacuum line is needed. You can re-use the long length from the existing setup. You do need to get the braided steel vacuum lines, though.
Old Apr 23, 2017 | 04:52 PM
MHarris's Avatar
MHarris
Does anyone know what the vacuum hose size is? I want to purchase some ss braided hose for my new switchpath that is on it's way.
Old Apr 27, 2017 | 03:01 PM
bittrl1000's Avatar
bittrl1000
Just measured roughly 1/8" inner diameter. This is for the white plastic tubing.
