Is it possible to program out the pops and crackling on decel w/ PSE?
#181
OK. In my case the only time I've experienced a variance with similar driving is with temperature. When the exhaust is cold, there is little or no popping. If the exhaust is hot when I aggressively push to redline and abruptly take my foot off the gas pedal, I can guarantee a 4th of July sound effect. And that will happen 100% of the time.
#182
For what it's worth this happens on the gt4 as well. The issue I have with them is they didn't bother programming any randomness into them. I forget the exact pattern, but every time you lift off you get 'gurgle pop pop pop gurgle'. Once the pattern is burned into your subconscious you almost cringe on lift off as it goes through the 'g p p p g' routine again. I had a w204 c63 and they nailed it on that as it was seemingly random, so therefore felt less artificial and become something you could enjoy.
I think in the case of a race car, the sounds are the consequence of tuning for power but in the case of a street car (which has to pass sound and emission standards) the sounds exist because customers want them and not due to the consequence of something else. A case in point is that the 991.1 makes more pops and gurgles in Sport+ mode than it does in Sport mode but the 991.2 makes less noise in Sport+ - the consequence of techniques to reduce turbo lag by keeping gas flow through the turbos at a maximum.
Would be curious to know if anyway successfully tuned these out via Cobb or other means.
#183
I didn't like the popping sounds when I use to race in SCCA events several decades ago, and I especially don't like them when they are contrived. As a matter of fact, I haven't met many people who like the popping sounds. The sound of a well tuned sports car engine running near redline is music to my ears, but the contrived popping sound is just noise as far as I'm concerned.
#184
However, my comment was directed to bardman, who said the pops on his GT4 always followed a specific pattern, as in number and types of pops are always the same. I never hear anything like this.
#185
I love the pops. Re their artificiality, I'm not disputing it but can anyone explain why if you put an aftermarket
can on a bike, as I have done many times, it pops, but the stock exhaust rarely does. All that has changed
is a bit of hardware.
#187
Just a guess but it could be that you had the pops before. The aftermarket exhaust amplified the sound and made it were it is easier to hear it within the cabin. The other possibility is that the aftermarket exhaust provides less back pressure, thereby allowing some unburnt fuel to escape before the exhaust valve closes.
#188
#189
Pops and crackles are way more pronounced in PSE mode as opposed to SPORT &PSE. I LOVE IT!
#190
So I ordered my first Porsche on Tuesday and included PSE in the option list. I have been reading the 2017 owners manual in my spare time and came across the car behaviour in various sport chrono modes and found that "backfire" is enabled in sport, but not in normal or sport plus. That would seem to indicate that it is programmed in. I wonder if anyone with PSE can tell us whether the pops are present when in sport plus mode??
#191
#192
You can detect a difference in the engine sounds however and once you realize that they have shut off spark and fuel but kept the throttle open (and presumably the waste gates closed) to keep air flowing through the engine and turbos to reduce turbo lag - you can hear the "pumping" effect.
