Is it possible to program out the pops and crackling on decel w/ PSE?
#151
Originally Posted by Churchill
STG, you're a smart guy so I know you're capable of understanding the concept here, but you seem to be willfully obtuse in this thread.
Let it be explained for the umpteenth time what the issue is here:Thank you and have a nice day.
#152
I realize this thread is about tuning out the pops and burbles on the 991.1 but I just wanted to clear up this info on the 991.2 Sport Plus mode
Not plausible or a possibility. It's a fact. The 991.2 Sport Plus mode is different than prior NA engine models as JR pointed out.
Try lifting off in Sport Plus and coasting. You will see it build up to 2 PSI of positive turbo pressure AND you will hear the air going through the engine. It sounds very different on coast down than Sport. The throttle body is kept open, and they shut off fuel and spark, so the engine acts like an air pump just sucking in air and exhausting it, keeping the turbos spinning. This also happens when you reduce throttle, not just a full lift, so that the turbos are right there ready when you request more.
In just sport mode I HAVE seen it build 1 PSI in coast down, but it takes much longer than Sport Plus, which does it almost instantly. Also during coast down Sport pops and bangs and then goes nearly silent, where Sport Plus actually has some nice exhaust tone due to this anti-lag feature keeping the turbos spooled.
Exactly right:
"The most important new feature comes in the form of an anti-lag system that brings the all-important instant response.
As opposed to the aggressive, turbocharger-consuming setup seen on rally cars, Porsche engineers went for a milder approach, basically turning the engine into an air pump during the overrun phase.
Take your foot off the gas and air will continue to flow into the cylinders. Since the air is compressed by the cylinders, this maintains the turbo's spinning state, thus minimizing lag.
Since the system's effect is more noticeable on the Sport and [most noticeable] Sport Plus driving modes, your 911 won't deliver unexpected boost surprises during busy traffic moments."
"To minimize lag, the mono-scroll, fixed-vane turbochargers use a vacuum-operated wastegate system to manage charge pressure. Additionally, whether at full throttle or completely off the gas, air is flowing to the turbos to help them spin. More importantly, the compressors do not need to build up a very high pressure.
If things are as you report on your car, it sounds like there's something wrong with it. Every 991 I've driven in Sport+ has been MORE pops and burbles than Sport or normal.
To be fair, that's all been 991.1s; I suppose it's possible the .2s have it dialed out for Sport+, but that doesn't make any sense. Sport+ is MORE of everything, not less.
But what I also noticed is that even light throttle and (relatively) low RPM in Sport+ shows some turbo boost - maybe as little as 1 or 2 psi but from there it increases quickly and the engine is very "torque y". Driving exactly the same way in Sport shows positive pressure only at higher RPMs and more throttle.
Specific to the 991.2 (not applicable to the NA 991.1) and that is send as much exhaust gas as they possibly can through the turbos in Sport+ - thus getting less turbo lag (they are already spinning faster than a simple idle) and more torque - which is also apparent in the general "feel" of the engine. The downside (if you can call it that) is that the path through the compressors may have a similar effect on the burbles as disengaging PSE and increasing the back pressure - it quiets them down to a level more consistent with PSE off.
#153
Fascinating post Jenner and thanks for sharing the information. As you note, I guessed they were doing things with the 991.2 because of my observations of my own car. I can pretty easily see how shutting off spark and fuel and holding the hrottle body open on overrun would have a side effect of reducing pops and burbles though it sounds like the real intent was to keep the turbos spinning.
#154
Basic Sponsor
Exactly right:
Exactly right:
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
#155
Plausible
superficially fair, reasonable, or valuable but often specious
Fact
a thing that is indisputably the case.
It's more than reasonable or probable...its 100% true/correct.
The 991.1 and 991.2 Sport Plus modes are totally different.
No pops, bangs, etc on throttle lift on the 991.2 Sport Plus mode. No turbos to keep spooled on the 991.1.
Fact
#157
"Possible" is the word that conveys the "often specious" implication.
Me in October: I bet Mr. Trump will be President in January.
Reasonable person: Well... that's possible.
Unreasonable person: Yeah.. that's plausible.
plau·si·ble
ˈplôzəb(ə)l/
adjective
(of an argument or statement) seeming reasonable or probable.
"a plausible explanation"
synonyms: credible, reasonable, believable, likely, feasible, tenable, possible, conceivable, imaginable; More
#158
I spent a few seconds on google...so can you:
http://lmgtfy.com/?q=plausible+merri...ter+dictionary
Bold is usually used for emphasis and of course I added it on my own, how else would it get there?
Not sure what your issue is. You didn't know what you were talking about as you were speaking only from your experience with the 991.1. I backed up what JD already said and quoted what's really going on with the 991.2.
You said it "doesn't make any sense" to you. I made sense of it for you and anyone else who might wonder why Sport Plus behaves differently than you might expect.
#159
Regardless of the argument here...
... I think it is certain that you could have the vent open with reduced burble and farts on either model. I described a method to finding out many pages ago. It should be tried by somebody who rates this as important.
#161
Regardless of who's right about turbo behavior in various modes, adding a connotation of speciousness to the primary definition of "plausible" is just plain wrong. It cannot possibly be justified by a survey of English usage.
Not every day you find a bug in the dictionary, especially not M-W, but that's a legitimate one.
#162
Evidence that on the 991.2, Sport mode has the most popping and gurgling by far:
https://www.youtube.com/watch?v=bc6kKynhBqo
I'm interested in playing with the mix/match options on Individual, as well.
#164
I pointed out way back that somebody's description of pops and burbles didn't match my experience, said perhaps that was a 991.2 thing, he explained how it was a 991.2 thing and why he thought (or theorized, if you will) that was the case, and I said that theory sounded plausible. Which means likely, believable, reasonable. Not absolutely true, but nothing about it casts doubt on the theory. Had I said it sounded "possible", that would have implied I was allowing the physical possibility he could be right, but I didn't find it likely that was the case.
Plausible implies a "wide gap" of likelihood, where possible implies a narrow gap; plausible implies that I'd be surprised if you're wrong, where possible implies I'd be surprised if you're right.
You came along and apparently (I didn't read your explanation; like I said, I don't have any interest in the 991.2 right now) "proved" that what I said was plausible was in fact the case. So you merely affirmed my comment. Meaning we are on the same page. So when you began your response to my comments with "No", I realized you had a fundamental misunderstanding of the word "plausible." So all this time I've simply been performing a PSA for you on the word. No need to thank me -- being right is all the thanks I need.
#165
Wow...I dropped it yesterday, thought you did too. You need to get over yourself! Don't pull a muscle patting yourself on the back
We are all Porsche fans here. Even if we don't agree....have a good one. I'm done with this topic.
