Feature coding?
Old Aug 18, 2016 | 10:35 PM
Chris C.'s Avatar
Chris C.
Originally Posted by P991GTS
On mine, the climate settings can be saved to memory (1, 2 and/or Key). I like starting the car without the load of the A/C.
The radio is a frustrating one. When I remember, I hit the source button and select AUX (I don't have anything connected to it) before shutting the engine off. If I don't, the radio comes on the next time; even if I was listening to music via Bluetooth when I shut it off.
Rarely use A/C in SF, it's always off at start-up on my car...linked perhaps to memory package?
Old Aug 19, 2016 | 02:42 AM
DannieK's Avatar
DannieK
To avoid having the radio turn on every time you start the car hold the on/off button down for at least 5 seconds before turning the car off. The next time you start it up the radio will be off. That works for 2016 models and earlier. Don't know if the same applies to the new PCM and ApplePlay.
Old Aug 19, 2016 | 08:05 AM
bmedude's Avatar
bmedude
I would love to enable roll up and roll down with the fob.
Old Aug 19, 2016 | 09:42 AM
911Forever's Avatar
911Forever
I find it interesting that my $35K 2011 Honda Pilot has this capability but not in our $100+K 991.
This is just a s/w coding that would not add any weight and with a minimal s/w programming cost but I'm sure Porsche has some rational reason not to add it.
Old Aug 19, 2016 | 11:28 AM
JW911's Avatar
JW911
Originally Posted by BIGWORM
I simply want Windows up/down with keyfob. I enjoy rolling them down as I walk up. And I enjoy rolling them up as I walk away. It makes entering it more comfortable and locking up a little faster.
Smarttop allows you to do this on a cabriolet or targa. I think coupe owners are out of luck.
Old Aug 25, 2016 | 04:05 PM
BIGWORM's Avatar
BIGWORM
UPDATE:
I was able to have my DEALER enable some features to my 2017 911 S. Windows will now go down with unlock if I hold it. My glass roof will open too!
I got a couple other things programmed the way I wanted too.
But they could NOT figure out how to get the MPH LIMIT off the PCM and on the MFD. They said it was "enabled" to do so, but it has not shown up on the MFD yet.
Just thought I would let you guys know the 2117 911's CAN get windows DOWN and glass top open with unlock if you want. They can remove a lot of NAGs too. Some they might not want too, but they might if you ask nicely...
Tipping new service reps 20 bucks the second I meet them has always served me well. Today, I got exactly what I wanted and it didnt cost me a dime, other than the 20 bucks I tipped.
Old Aug 25, 2016 | 07:21 PM
rkwfxd's Avatar
rkwfxd
That's good to know. I miss the windows up when locking with the fob that I had on my 996.
Old Aug 26, 2016 | 08:45 AM
Jabs1542's Avatar
Jabs1542
Are you sure about that? Aren't 1's heavier than 0's!
Old Aug 26, 2016 | 11:57 AM
Curvfun's Avatar
Curvfun
UPDATE:
Tell us what else you were able to get changed besides getting the windows to go down with the unlock button? I'd like to understand what the dealer can do in case I'd like some of the same changes. For instance, on the '17 991.2 S, if you open the door while you have the car in gear, it sets the parking brake. So, if you open the door to check out how close to a curb you're parking, you have to release the parking brake to make it go. Plus, it will not go at all with the door open. Drives me crazy trying to make minor parking adjustments.
I have several BMW's that I've changed all kinds of stuff on because the s/w for doing it is generally available. I wish someone would find a similar application for us to use on the Porsches.
Old Aug 26, 2016 | 02:30 PM
Peruna's Avatar
Peruna
UPDATE:
Awesome! Did you happen to ask whether they can do the same with a 991.1?
Old Aug 27, 2016 | 03:19 AM
amet's Avatar
amet
my 991.1 does that , I figured it was like that by default on all.... first thing I tried coming from VW where this is a standard feature as well.
hold lock on keyfob will close the windows and sunroof and unlock will roll them down and open the sunroof.
