Post Random Discoveries About the 991
#47
#48
Went out on a spirited back road drive today and had sort of an epiphany about the PDK transmission. When we picked up the car my sales guy basically told me not to use Sport+ because it shifted at redline and was for the track. So until today I have not used it. I come from a sport bike background so learned a way to shift a bike with a manual transmission in the twisties and the PDK seemed a lot different that that in either auto or manual in sport mode. Today I decided to give sport+ a try in auto mode and of a sudden the way the car was upshifting and downshifting and blipping the throttle made total sense and was very similar to how I shift a bike. And no, the car does not shift at redline all the time. Maybe at wide open throttle, otherwise it shifts well below redline. So I discovered that sport+ is just great for spirited back road driving and the handling of the car is better too. The PDK was doing almost exactly what I would have done if shifting in manual. I won't use sport+ very much, but now the PDK makes sense to me as a performance transmission.
#50
#51
It's not a "comfort mode" because the gears are shifted at higher RPMs and if you're in slow traffic you may end up in 1st the whole time but you really get to enjoy the engine for what it was made for and It comes up alive. I remember when I test drove a Turbo S (my first experience with Porsche before buying my GT3) the sales man told me "now it's gonna get fun" and then click the button! It was awesome!
#54
Sport: The SPORT button on the center console is fitted as standard. When selected, Sport mode is activated to provide greater response and enhanced driving pleasure. Throttle response becomes even more direct, the rev-limiter is adjusted to a harder setting and engine dynamics are tuned for performance driving. The auto start/stop function is also deactivated.
With the optional Porsche Doppelkupplung (PDK) transmission, the shift points are reconfigured to operate at higher engine speeds. Shift times are reduced and gearshifts become firmer and more immediate, while throttle-blip downshifts are accompanied by an emotive engine sound. Coasting mode is deactivated automatically.
Sport+: the SPORT PLUS button. When this is pressed, optional Porsche Active Suspension Management (PASM) switches to ‘Sport’ mode for harder damping and more direct steering and therefore, even more intensive road holding. The trigger threshold for PSM is raised. Agility is perceptibly enhanced when braking for corners with PSM, allowing even sportier braking and exit acceleration. For even greater dexterity, PSM can be set to standby while the car is still in SPORT PLUS mode. For safety, it is set to intervene automatically only when ABS assistance is required. ...Porsche Doppelkupplung (PDK) is geared up for the shortest possible shift times and optimum shift points, while torque boosts during gear changes provide the maximum acceleration available. This involving experience is further enhanced by overrun downshifts and the throttle-blip function for uncompromising driving pleasure.
#55
#57
On one of my first drives, I pulled both paddles back to put the car in neutral at a red light so I could blip the throttle to show off my Porsche Sport Exhaust.
Uh . . . it will not go back into gear when the light turns green to go unless you have your foot on the brake. All those folks behind me formerly impressed by my Porsche Sport Exhaust started honking their horns at me to get moving as I tried to get it to go back into gear.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
#58
Sport+ pdk in manual- have not been able to get 7th. Maybe if I read the manual these things would not be on the fly revelations. Or go faster and it will give 7th
#59
Sales guy told me that car hits top speed in 6th, and 7th is more of an overdrive. Of course he is the same guy that told me some bogus info about Sport+, but I can see that the car might not shift into 7th in sport+ because it would drop the revs too much for max power.
#60
Edit: (Oops I guess I missed the post just before mine!)
