Dent in door jamb, was car possibly in an accident?
Old 07-12-2016, 12:42 AM
Cdub2235
Cdub2235's Avatar
Default Dent in door jamb, was car possibly in an accident?
Hi all,
I noticed something on my new to me 13 C2S, theres a dent in the door jamb...I was told at a body shop that this is likely because the car had an impact. I wanted to get opinions on here as well, if you look at the two pictures you can see there clearly is a dent and some paint missing.
Door Jamb
Door:
What do you guys think, did I get the run around? This car has a clean car fax(which I learned can't be trusted) and I also took this car in for a PPI from a recommended Porsche indy shop, which they said it was clean. Past weekend I took into a body shop to get a quote on a scrape and they're almost 100% sure the cars been in an accident. Please share your thoughts.
Thanks!
Old 07-12-2016, 02:11 AM
Pmorritt
Pmorritt's Avatar
Too close up. Don't know what I'm looking at. move back to see where we are talking about
Old 07-12-2016, 02:15 AM
roberttran1985
roberttran1985's Avatar
Maybe someone closed the door on the seat belt buckle.
Old 07-12-2016, 02:36 AM
MinMay
MinMay's Avatar
it's hard to tell based on those pictures. if you see any wavy lines, then it was probably hit (minor). do you have a paint meter? there are VIN stickers on 4 panels. if you are missing any of them, then it had been replaced.
Old 07-12-2016, 03:13 AM
Cdub2235
Cdub2235's Avatar
It's the driver side door jamb, where the door sits when it closes against the door jamb.
Old 07-12-2016, 03:16 AM
Cdub2235
Cdub2235's Avatar
I wish it where this, but it's on both sides, drivers as well as passengers, it's less notcible on the passengers though. Here's the passenger side. Same spot.
Also the Drivers side door has a few marks that looks like some chip repair was done or paint was sprayed over it, and parts of the drivers side paint appear to be wavy..you have to look at just the right angle in direct sunlight.
Old 07-12-2016, 03:17 AM
Cdub2235
Cdub2235's Avatar
I and a body shop did notice some wavy paint on the driver side door...
Which 4 panels are you referring to for the vin stickers?
Thanks!
Old 07-12-2016, 06:47 AM
bmedude
bmedude's Avatar
That white stuff resembles body filler. Howndoesnthe car drive? Touch it up and call it a day.
Old 07-12-2016, 09:06 AM
STG
STG's Avatar
I'd have a reputable body shop look at the car. Someone that knows what they're doing will be able to tell if the car was resprayed in certain areas and could find more clues and give an accurate assessment of what previously happened.
Shouldn't be that big of a mystery.
Who did you buy it from? Mileage? Year?
Old 07-12-2016, 09:22 AM
stealthboy
stealthboy's Avatar
I would guess there was a front-end impact. I've seen this on another car. The doors would be pushed back into the jambs like that.
Old 07-12-2016, 10:21 AM
brad@tirerack.com
Former Vendor
brad@tirerack.com's Avatar
Do these cars flex enough to do this if jacked up without the doors open? Corvettes do.......
Old 07-12-2016, 10:36 AM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,132 Likes on 677 Posts
That's interesting
Old 07-12-2016, 12:27 PM
n8kruger
n8kruger's Avatar
It looks like the belt buckle dented the bondo from a previous hack job. Closer to the door gasket on the left in the first picture looks like the paint overspray fades out underneath the rubber boots.
Old 07-13-2016, 07:32 PM
AF330i
AF330i's Avatar
The point of the door meets perfectly to the point of the car jam has the 'damage' ?
I would bet the car is totally fine ... if the car was in an accident wouldn't they have repaired it and there would be no paint chipped ?
When I study my cars which haven't been in any accidents I will always find things that I find not perfect ... it is funny sometimes something happens to my cars and I look at it and say to myself ... the next owner will think something happened that was much bigger then what actually happened ...
Old 07-13-2016, 07:37 PM
JW911
JW911's Avatar
Really hard to see anything meaningful in the photos. But my bet is on a seatbelt being slammed in the door. Had this on my old car. Paint needed a touchup.
Quick Reply: Dent in door jamb, was car possibly in an accident?
