1st Oil Change dufus
#31
Originally Posted by ArthurVandalay;
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/image_5356d8b0815a9b64fd016a260d359e19ff90e836.jpeg)
#32
Thanks. The 'hole' accesses a large unfinished portion of basement. That is where all the garage junk is stowed. Only things in garage are two cars and the cargo bike.
There is enough room to hop in the hole with the car backed on it. Kinda got the idea from jiffy lube and an old midwest cellar access door, but inside the garage.
The door is 50" Wide. The hard top to our jeep actually fits in the hole, through the door, and into the storage area. Pretty much the parameters for the design.
The oil change capabilities for the jeep and now the 911 are a happy accident.
Thanks again for posting your oil change tips.
Fastrr- the Bullitt is THE. BEST. BIKE. Fun. Have over 10,000miles on it. For our now three year old. Two hours a day on it at least.
#34
Unless one knows the composition of the "O" ring material, it may be best to stay away from the Vasoline. It could actually degrade the ring, if rubber is a significant component.
#35
Great info here. I have always changed out my new engine oil at around 1k. Nobody mentioned the way to get the fans out of the way for oil filter acess.
I have seen picturesults here with them off but explaination. thanks
#37
Remove cover 1st plastic tabs to fan housings...... then the fans pull out of their rubber socket mounts that are in the sheet metal.
Real easy to pull apart.
#38
This video is pretty good. First thing the tech removes is the fan shroud. No explanation of what he's doing while he's doing it. Watch the entire vid.
#39
Don't over complicate the process. There is no need to remove the fans from the housing. Simply lift up the two corners of the entire assembly from the bottom that is closest to your body. Then pull it towards you as angle it upward. Remove the two fan electrical connectors and that's it. The entire assemble, fans included can now be removed intact.
#42
A good diy oil change thread here:
https://rennlist.com/forums/991-diy/...il-change.html
Take care not to lose the rubber grommets when removing the fans & cover.
#43
1) there will be blood at some point, and
2) any small dropped parts will roll as far as possible from the initial point of impact. No need to look directly beneath the car.
