1st Oil Change dufus
Old 06-12-2016, 09:44 AM
Chiboy
Chiboy's Avatar
Originally Posted by 991carreradriver
You overpaid, cost me $65. Walmart had a 5 qt special for $22.48.
Where do you get the filters? the Mobil-1 oil is cheap, but my local dealer now charges $40 for filter, o-ring and crush washer!
Old 06-12-2016, 10:06 AM
LonnieR
LonnieR's Avatar
I give everyone on the forum that can do their own oil changes,etc. credit. I learned a long time ago with my first 911 (it was a 1971 911T) that all I had to do was make one small mistake and the costs and inconvenience factor went up geometrically.
If you get pleasure out of working on your car, that's great. At this point I'm just glad I can drive the s--- out of my 991 and have my local Porsche specialty shop service the car when needed.
Old 06-12-2016, 11:23 AM
stealthboy
stealthboy's Avatar
I bought two of those 5qt jugs from Walmart, so I included both in my cost. Filter and rings were $40.
As long as I'm under $100 for the whole thing I'm happy.
Old 06-12-2016, 11:34 AM
CSK 911 C4S
CSK 911 C4S's Avatar
Here's a good filter source. I change mine every 5K miles so I buy 6 at a time or so.
https://www.ecstuning.com/Porsche-20...ers/ES2535384/
https://www.ecstuning.com/Porsche-20...ers/ES1441757/
Old 06-12-2016, 04:14 PM
ArthurVandalay
ArthurVandalay's Avatar
Paid $361 for oil change last week at the dealer. Planned for that.
Thanks for posting the tips on oil fill and filter replacement. You guys are great.
Tried out my 'poor man's lift' today. Total access to underside of motor. In 3-ish thousand miles I'll be attempting.
Old 06-12-2016, 04:27 PM
CSK 911 C4S
Old 06-12-2016, 04:29 PM
991carreradriver
991carreradriver's Avatar
S
Suncoast has the kit for $29.50 Follow the link http://www.suncoastparts.com/categor...GINEmaint.html
Old 06-12-2016, 04:58 PM
fastdiablo
fastdiablo's Avatar
Pelican parts.com is another dirt cheap source for filter/crush washer/ gasket. Great service.
Old 06-12-2016, 05:10 PM
Al.Fresco
Al.Fresco's Avatar
And they say the Germans are the best engineers!!!
Old 06-12-2016, 06:28 PM
Brian E
Brian E's Avatar
S
Do you know if this kit comes with the lube that Porsche specifies to use on the o-ring?
Old 06-12-2016, 07:56 PM
Chiboy
Chiboy's Avatar
I have always used just a bit of the oil on the o-ring. Is there really special o-ring lube?
Old 06-12-2016, 08:09 PM
991carreradriver
I have been changing oil filters for a long time. Forget the "O" ring lube and use some clean fresh motor oil. Works perfectly.
Old 06-12-2016, 08:19 PM
satoru
satoru's Avatar
Either clean engine oil, or vasoline. If you really want to get fancy you could get some Parler-O-Lube in the black and yellow tube.
Old 06-12-2016, 08:20 PM
trucheli
trucheli's Avatar
The answer is no. Besides, it's grease not lube and I would follow Porsche recommendation. There's always the right way of doing things and your way.
Old 06-12-2016, 08:25 PM
satoru
satoru's Avatar
CSK 911 C4S...WoW!!! Thats one cool custom setup!!! Is the door behind car used for access to get under car? If so, that's super clever!!!
Quick Reply: 1st Oil Change dufus
