Passenger Mirror Tilt Down Problem
I have this exact problem with my 2014 C2. Box is checked in settings, right mirror is selected on the door panel and when I put the car in reverse, the mirror does not tilt. Sometimes it moves slightly, but it does not tilt all the way down as it should. Adjusting the mirror works fine in all directions, so the motor is okay. I'll be having it checked at the next service.
The last post is what will have happened. I thought mine was wrong and the tilting only worked on one key, you have to program exactly how it tilts - and per key memory as well.
Put your car in reverse, let the mirror tilt whichever way it does then while still in reverse adjust the mirror to where you'd like it to point and presto,,,, done deal.
when you put it back in drive it returns to its normal driving position and next time you put it in reverse it will be right where you want it.
