DIY: AWE Switchpath install (GTS)
Old 04-17-2016, 05:33 PM
  #31
Larry Cable
Larry Cable's Avatar
Received 3,604 Likes on 2,343 Posts
Default Step 2.12: bumper removal
Finally the bumper is ready to remove! "gently" pry each side of the bumper away from the bodywork at the edge of the rear wheel arches, this will just pull out.
Then pull the bumper backwards and up slightly to free it from the back of the car. TAKE CARE not to scratch the bodywork as you remove the bumper.
have a soft surface ready, out of the way of the work area to place the bumper cover
Old 04-17-2016, 05:37 PM
  #32
Larry Cable
Default Step 3.1: heat shield removal (side)
remove the T25 screw on either side of the car's heat shield
Old 04-17-2016, 05:39 PM
  #33
Larry Cable
Default Step 3.2: heat shield removal (back)
remove the 3x13mm(?) bolts on either side of the crash protection bar, at this point it is free to remove. tilt slightly upwards and pull back, WARNING ITS HEAVY!
Old 04-17-2016, 05:43 PM
  #34
Larry Cable
Default Voila! now you are ready to remove the OEM PSE
Perhaps now is a good time to install some BMC air filters?
Old 04-17-2016, 05:47 PM
  #35
Larry Cable
Default Step 4.1: OEM PSE removal, engine vacuum line
gently pull the vacuum line connecting the valve actuators from the engine...
Old 04-17-2016, 05:50 PM
  #36
Larry Cable
Default Step 4.2: OEM PSE removal, OEM Tips
using a female E12 torx remove both OEM exhaust tips
Old 04-17-2016, 05:55 PM
  #37
Larry Cable
Default Step 4.2: OEM PSE removal, clamps
using an M6 hex head, loosen the band clamps retaining the PSE exhaust, soon you will slide these outwards immediately prior to removing the exhaust
Old 04-17-2016, 05:59 PM
  #38
Larry Cable
Default Step 4.3: OEM PSE removal, collar release
release the collars by loosening the 12mm bolts, and slide them to the outside releasing the center section
Old 04-17-2016, 06:02 PM
  #39
Larry Cable
Default Step 4.3: OEM PSE removal, detach PSE from cats
almost ready to remove the PSE; but you have to unbolt the 3x12mm bolts connecting the exhaust to the cats... (using this photo to better illustrate the location of the nuts in question)
Note: you may need 12mm "deep" socket or an "offset" wrench to remove nuts from the cat studs
BTW: when/if you ever restore the OEM exhaust you may find it difficult to re-seat it on the studs attached to the cats -
I actually had to use a rachet-ing cargo strap to slightly "pull" the cats together in order to get the OEM exhaust back onto the car.
Also, replace the OEM "crush" gaskets between the cats and the exhaust when doing that...
Old 04-17-2016, 06:06 PM
  #40
Larry Cable
Default Step 4.4: OEM PSE removal, loosen side exhaust brackets
In order to fold back the side exhausts, it helps to loosen the bolts on the brackets here...
Old 04-17-2016, 06:09 PM
  #41
Larry Cable
Default Step 4.4: OEM PSE removal, pry brackets off of cats...
pull the brackets supporting the side exhausts off of the cats, then swing the side exhausts out to the sides... <br/><br/>YOU CAN NOW PULL THE BAND CLAMPS OFF AND REMOVE THE PSE
Old 04-17-2016, 06:12 PM
  #42
Larry Cable
Default Step 5: install AWE SwitchPath
At this point, you are now ready to install the SwitchPath exhaust, the AWE
instructions here: http://www.awe-tuning.com/media/pdf/...th_exhaust.pdf are very good so I wont "step-by-step" it much if at all now.
Old 04-17-2016, 06:29 PM
  #43
Larry Cable
Default Top Tip: pre assemble and partially crimp vacuum lines ...
Note: the GTS requires a 17" drivers-side vacuum line, which is 2" longer than the std 991S 15" line described in the installation notes.
AWE have been made aware of this by FastDiablo and I, they *should* be providing longer hoses w/GTS kits, so check with your dealer!!!
Update: the AWE installation instructions have been updated, as has the length of supplied hose to accommodate the 17-18" GTS drivers side hose - FAST WORK AWE
Even with the back off of the car, once you install the SwitchPath there is not a great deal of room to work,
this most impacts the ease of the task installing the vacuum lines.
My recommendation is as follows:
1) pre-assemble the drivers & passenger side lines with the T-connector, and crimp the connections to the T-connector *and* the valve actuators on either side of the SwitchPath *before* you mount the exhaust section on the car
2) attach and crimp the 1.5" hose section to the engine vacuum connector *before* you mount the SwitchPath on the car
3) place a crimp ring on the 1.5" hose prior to mounting the exhaust
4) once the exhaust is mounted, then connect and crimp the T-connector to the 1.5" hose previously connected to the engine.
Note: you can either use the special tool, here: http://smile.amazon.com/Oetiker-1410.../dp/B008L489P0
But... something like this will also work: http://smile.amazon.com/Klein-Tools-.../dp/B0002RI9NQ
Old 04-17-2016, 06:32 PM
  #44
96redLT4
96redLT4's Avatar
Wow! You are like a master pathologist with that dissection of a Porsche rear end Larry. Great pictures. If I drive up to the Bay Area will you do mine for me?
Jim
Old 04-17-2016, 06:35 PM
  #45
Larry Cable
Jim
I should have been a proctologist!
Quick Reply: DIY: AWE Switchpath install (GTS)
