S PSE vs. Non-PSE
#62
Originally Posted by bittrl1000
Could I ask you to be more specific? How difficult is it to install non-PSE tips on the PSE? Or what are the consequences of doing so?
If you look at the pics, the inner pipes are cupped and a pressure fit. That's where the tips fall 1/2" short.
Of course, some aftermarket tips will work too.
#63
They install on the clamp side. On the inner pipe, the S tips are about 1/2" short of a snug fit on the PSE setup. If you look at the pics, the inner pipes are cupped and a pressure fit. That's where the tips fall 1/2" short. Of course, some aftermarket tips will work too.
#64
http://www.6speedonline.com/forums/9...ts-prices.html
In this thread, at least 2 people claim to have reused the standard tips when installing the PSE on their 991S cars. So now I'm confused, because one person here is saying its simply difficult to reuse the standard tips, another person says they were told you can't reuse the tips, and the people on the other thread say you can, without saying how difficult it was.
I guess I may just have to try it myself and if I can't make it work, I'll order the PSE tips or hopefully something less expensive.
#65
You cannot reuse the standard tips and here is why.
See these examples:
PSE style:
http://www.fabspeed.com/porsche-991-...tyle-tips-pse/
non PSE:
http://www.fabspeed.com/porsche-991-...-tips-non-pse/
PSE has 2 pipes for each side (4 total) that correspond to the 4 tips. NON PSE has 2 pipes (2 total) that connect to a "Y" style tip on each side and look like 4 for aesthetic reasons only.
#66
The "S" tips will fit on a PSE exhaust and clamp on. No risk there.
For the one exhaust on each side (closest) to the license plate, you'll notice there will be a 1/2" gap of it not completely connecting. This is not the clamp side, but the cupped pipe that is just a pressure fit.
If you're ok with that, that's fine. Me personally I wanted the whole exhaust pushed out the tip and not floating under my rear bumper.
I've actually tried these configurations and know.
The PSE tips are like $1,200 for the pair ala carte. You're better off ordering the whole PSE kit (includes tips) rather than messing ordering separate parts trust me. Geez, the complete system is only $2,500 for everything!
#67
My experience was the same as R_Rated. I was told that the non-PSE exhaust had a single pipe connector and the PSE had a double, hence no way to mount the non-PSE tips on the PSE exhaust. Note, my installer had no reason to lie, as I already had the full kit in hand.
I wonder if people who have used the non-PSE tips have either not changed out the section leading to the tips or fabricated a 2 to 1 connector.
#68
Correct - just look at the pictures in the links I posted!
btw... for people with too much $$$ here are some PSE tips in black for 2,000+!
http://www.suncoastparts.com/product/SKU991GTSTIPS.html
#69
See these examples:
PSE style:
non PSE:
See these examples:
PSE style:
non PSE:
Thanks for your help STG991. I think I understand you now. And if I do, I'd say that I'd probably be ok with a small gap between one pipe on each side and its tip, since that seems to be only a cosmetic issue if one looks real close under the car. And if I change my mind, it seems I can order some PSE-compatible tips for no more than what the actual PSE tips would cost originally.
#70
I believe you and Archimedes are referring to a standard 991. I have a 991S.
#71
Originally Posted by Archimedes
Nope, I have an S with twin tips as well. Dealer said they would not mount properly on the PSE exhaust.
They do mount, but with the shortcomings mentioned.
#72
#73
The left side is the one that will have a gap of about 1/2" with the "S" tips on a PSE exhaust.
The right clamp side will fit no issues.
If you want pics of BOTH S and PSE tips side by side I can send some to you sometime. PM me. They look identical in pics except for the finish and this short measurement. Just idiotic of Porsche to do this. Only reason being wanting you to buy new tips.
#74
In the big scope of things, the small gap shouldn't be a big deal. There's so much force coming out of the exhaust it's all getting blown out.
Also- - you will lose some of the aural benefit since the sound will not be directly exiting the car and in fact hit the outside of the exhaust tip instead.
#75
Originally Posted by R_Rated
It's a jerry rigged setup on a 100K car IMHO. yes it will work but the exhaust will blow on the back of the pipe and potentially start to melt the bumper. With using S tips on PSE is no different than using base tips since either way the exhaust is not blowing out of the tip.
Just outlining the facts about the differences of the two which nobody has been able to answer.
