S PSE vs. Non-PSE
#47
Meh, as a pilot, it's just part of the checklist. I've had the car for less than a month, and that is as automatic as hitting the garage door button, once the ignition is switched on, prior to startup.
#49
#50
What you are looking at are the actuators for the valves, and yes you should see them move with a press of the Sport Exhaust button. Note that the exhaust comes in two configurations (at least that's what I have seen), in one configuration the valves are in the center of the rear (as shown in the photo), and in the other configuration they are towards the sides.
#51
That's what I thought. I have a new to me 2012 and the PSE wasn't working. I took it in they replaced a vacuum actuator and said it was good to go. There is now a noticeable (though subtle) change in exhaust sound when the PSE button is selected but the valves don't appear to move. Can anyone confirm that the valves should move when you select the PSE button, even when sitting at idle?
#52
Good thread here about PSE and parts required for S retrofit
http://www.6speedonline.com/forums/9...ts-prices.html
Ordering the parts seperately (not a kit) and skipping the chromed exhaust tips cost him $1,240.
I'm tempted to do the install and just take to the dealer for programming... anyone seen a DIY?
I read a couple of people have done it...
#54
This link walks you through removing the stock 991S exhaust, and I believe installing the PSE is just the reverse (except for the need to extend the vacuum lines to reach the centerpoint of the PSE).
I plan to do this install myself late this spring or early summer. I plan to buy only the PSE center muffler, gaskets, hoses, and new keypad for console. Looks like it can all be done for about $1,000 in parts (not to mention the net cost after selling the old center muffler).
#55
#56
Very informative post, as I have a non-PSE car and have been considering adding it (at an earlier suggestion from STG991). Now it will be a definite add because I happen to like all of the burble and pop associated with it. I drive through a lot of wooded countryside and believe I would be able to enjoy the music. Based on what I have heard it adds to the character of the car.
#57
#58
Suncoast sells the complete PSE with tips for like $2,500. Cheaper now than when the guy bought all the parts separately. They had this kit on sale closer to $2K a few months back.
Try Sunset Porsche Parts in Oregon too. May be even cheaper.
#59
