Anyone know why?
#31
I have now received information from Porsche Germany through my OPC.
There would be no induction or cooling issues having a ducktail fitted to a GTS and not changing the GTS grill to a Carrera grill.
The only issue is from a legislation point of view, which is: only 3 brake lights should be visible on the car at anyone time.
The standard Carrera grill that should be fitted with a ducktail has a blanking plate installed to cover the original grill. And I presume that on a standard Carrera (without a ducktail), when the spoiler is raised and the spoiler brake light is visible the grill brake light does not light up and is not visible.
So all I will have to do is disconnect the GTS grill brake light and cover it up. Then the ducktail brake light will be the "third" light..
Hurrah, success... Now all I need is the car..
#33
#34
You can disconnect the light very easily.... If you don't like the "tape-over" approach. But I seriously would just let it go and if for some reason you get the dealer or someone complaining just pull the plug out. From road-level I don't think it is view-able with the ducktail on....
#35
Also, how do you plan on covering it up?
#38
Actually good point, I am doing the reverse, ordered the ducktail with the GTS, so my grill will have no 3rd brake light. I just need to swap out the grills, only dilemma is what to cover the brake light slot in the GTS grill with.
#41
As quoted on site..."The duct tail spoiler comes with the cut out to accommodate a 3rd brake light you can use the existing one from the factory popup spoiler."
