TPMS reset
Here’s a picture of the TPMS that was included on the wheel. I have a 991.2. There’s so many different brands out there, it’s helpful to see what’s on the wheels already.
TPS No Worky
I changed wheels on my 991.2, installing the HRE's i originally had on my 991.1. Using the same tps sensors that were working on the 991.1. My 991.2 does not recognize the tps and gave me a fault, indicating service required. 😕
Are the sensors different between the .1 & .2?
https://rennlist.com/forums/991/1166...t-numbers.html
if this does not work, remove tire from rim and reprogram, mount tire and balance.
polobai (05-11-2020)
You are correct. Strike what I said. This was based on what I was told when I was going to buy a used 991.1 turbo S wheel set for my 991.2 to be used as Winter set.
I went with a Porsche winter wheel set in the end. The Turbo twist wheel set was a direct match, I believe, to the winter wheel set that Porsche build for the C4GTS. Good warning to everyone to check widths and offsets.
Official Wednesday AM Red Bull F1 test driver
Another bump- just put new Michelins and new batteries in my '14 turbo S coupe. Couldn't for the life of me figure out how to get it to learn! RTFM didn't help as usual! Scrolling thru the tire selection did the trick!
After 2 days of going through every menu here is what I figured out. The sensors do not automatically sync. You have to go to the "TPMS" menu and where you can choose 20" summer or winter tires. You have to scroll from summer to winter and back to summer and hit enter. You will get a message that states that the TPMS is registering or monitoring. You have to keep it on that screen otherwise they will not register. After about 5-7 minutes they finally registered.
Just what i needed, having new sensors put in tomorrow. Thanks Rennlist!
You have found the missing link, congrats!
ATDesign (01-30-2023)
