20k service question - dealer ripoff?
So, I just got a 20k service from the dealer - I am at 13.5k miles but its been two years. There were a few surprises on the final work order, although the price was what was quoted.
The work order shows the dealer put in a fuel decarbonizer and ethanol corrosion preventer. Now, I know DFI engine are notorious for having problems with ethanol, but is this something normal that you have seen dealers put in?
Ok, so the second thing I noticed was just this evening when I was filling one of my tires (it was 1-2 psi off and I am kind of picky about that stuff). I opened up the frunk plastic cover to get the air pump out, and noticed the cabin air filter was a bit dirty looking. Popped the cover, pulled it out and found what you see in the images below. Now, I had only driven around 30 miles since I picked up the car - should the filter be that dirty after just a few miles?
I believe what you're trying to say is that the in cabin filter hasn't been changed and you would be correct 100%.
I have no idea what the 20K miles/2 yrs service entails,but that should be on your work order. I'm pretty sure it should include the cabin filter change. Those are usually recommended to be changed every 20-30K miles or 2 years,whichever comes first. It's all dependent of the environment where you do most of your driving(dust,AC usage etc).
In conclusion,I would definitely be very upset if the 20K service entailed a cabin filter change and I would discover it has not been changed.
Go back and let them know!
Yeah, that's what I thought it might be- but look at this link to the 20k service kit on suncoasts site:
20k service kit
The interior filter is a bit grey like you mentioned, but the one I am showing in the pics above is the skinny one that is all white.
Neanicu- yes, the work order shows the charge for both filters and the labor.
The thing is, they also said they fixed a suspension clunk that occurs at low speed, but it's still there. I am beginning to wonder if they did anything at all except a 4 mile joyride!
20k service kit
Yeah, that's what I thought it might be- but look at this link to the 20k service kit on suncoasts site: 20k service kit The interior filter is a bit grey like you mentioned, but the one I am showing in the pics above is the skinny one that is all white. Neanicu- yes, the work order shows the charge for both filters and the labor. The thing is, they also said they fixed a suspension clunk that occurs at low speed, but it's still there. I am beginning to wonder if they did anything at all except a 4 mile joyride!
http://science.howstuffworks.com/env...uestion209.htm
For the money Porsche is charging for these cars,I would think they would come with charcoal filters,but it looks like that's not the case and instead they use paper filters from the factory. So,the filter in your picture is most likely the original filter that came with the car from the factory.
Either way,one starts wondering what else have they NOT done. Oil change?
The oil could easily be legit. There's easily several quarts, probably more like 5-6, sitting in oil lines and radiators that never gets changed. If they somehow drained more than usual of this, or the car went from being a bit low to a bit high after, those two together could easily be 2 quarts.
Unfortunately, there are stories abound about dealers charging for work not done. I got charged $16 to refill/top off the windshield cleaner reservoir. Don't know how this could be since I never used it.
For the OP, routine mainainence, DYI. Find a different dealer for the warranty work.
https://pictures.dealer.com/porscheo...80174e8ce7.pdf
For the 20K service it should just be an oil change along with the 2 years the brake fluid flush.
Did you ask for the other stuff to be done?
Received 5,412 Likes
What was on the work order? How much did they charge? What did you ask to be done?
The 10 quarts of oil is a common shill game. Did they itemize each quart? You can't shoe-horn 10 quarts into a 991 9A1 motor.
I thought at 20k the cabin filters had to be changed? That was what suncoast, etc have in their 20k kit. I swear it was in manual as well, but based on the link to that PDF above I am not so sure.
As far as the oil goes, yes - they itemized each quart.
Then they either overfilled by 2 quarts or they owe you 2 quarts in a nice Mobil to go bag. Did they even use Mobil, or Penzoil?
Did you get the brake fliud flushed?
Your filter was dirty. It needed changing. Good on you for doing it. As long as they didn't charge for it, you're fine.
Just had my (2yr) 20k done even though I'm at 9k miles.
A whole lotta inspecting going on and an oil and air filter(s) changed.
Cabin Filter $$$, wipers $$$ and window cleaner.
Was charged over $700.00!!
A complete and utter rip off (as usual).
