CQuartz question/problem
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
I had CQuartz Finest professionally installed on my 911. He said he put three coats over the entire car. To be honest I really can't tell any difference in the paint or wheels. When I wash it, it beads, but it did before also. The wheels get dirty just as fast as before so don't see anything there. I drove less than 100 miles and have break dust all over the wheels. The only thing I can say is the windshield repels water. The paint surface is somewhat slick but not much different than before.
I assume it will protect the paint but was assuming the slick surface would repel dirt etc. as I have heard from others. I did not watch him as I was at work but assume he did what he said.
Any thoughts on users that have this? Is there something wrong with it or am I too picky.
Received 5,407 Likes
Did the detailer do a full paint correction, prior? How much were you charged? Why he needed to put 3 coats on is beyond me, but I don't know much about the CQuartz product.
My car was OptiCoat Pro within 4 weeks after delivery this spring. Full paint corrected (stage 1 and some stage 2) The dirt just falls off during washings. Haven't noticed it staying cleaner, longer, between washes.
Send a PM to Phil at Detailers Domain. Ask him why 3 coats.
If you want your wheels to stay clean, and repell dirt and brake dust for HUNDREDS of miles, start using Armor All Wheel Protectant spray. Great stuff.
Whether it's a coating like CQuartz/Opti-Coat, a sealant, or a wax; there is no such thing as dirt repelant. The coating simple adds a layer on top of your clear coat making it shine a bit more, bead water a bit more, and mainly help protect your clear coat from scratches and swirls.
Personally I don't like the look of coatings like CQuartz as you don't get as much beading and you don't get the "depth" you get from a quailty wax and some sealants. The trade-off is that you give those up in favor of durability and maybe a little extra protection. The coating won't look much different than your basic corrected/clean clear coat.
Unlike Opti-Coat that will not bond with itself, CQuartz can be layered as long as you let each layer cure.
I was told that it would keep the paint and wheels clean as the dust would fall off and not stick.
I will try Armor All Wheel Protectant spray and see how that works
Richard
Probably meant keep clean when you rinse. I have Opti-Coat on my car. The dust still gets dirt on it, but it comes off easily when I pressure wash the car. My regular maintenance is pressure wash rinse and then leaf blower dry. It keeps the car relatively clean, so I don't need to wash as often. Richard
The ArmorAll stuff does work, but it is messy and leaves the wheels looking very dull. And, its expensive because you have to use so much of it...and, if you miss a spot, you will definitely notice where you missed.
To the OP, there is no "magic cure" for not having to wash your car. They do get dirty from brake dust and soot. Its just a fact. The sealant just makes the washing easier.
Good luck!
I really don't expect a non-wash results but I have the same cleaning requirements after as before - especially on my wheels. I enjoy the washing part as many do but just like it to look the best between washings.
I am guess maybe he did not do exactly what he said. I may try some more CQuartz (I have a little left from his process) and see if there is a difference.
Thanks for the input
I have Opti-Coat.
No idea if it's easier to wash, but the paint is glossier and shinier. Not imagining it as I've had my car next to another silver C2 at the lot, and under the sun it's appreciably noticeable.
Did you get only the faces coated, or were the wheels removed and the interior coated as well? How about the brake calipers? I'm getting getting all of it done, because I'm hoping I can get it clean with just the Sonax wheel cleaner and minimize needing to get in their with a brush.
I did NOT take the wheels off and was still able to decontaminate the entire wheel, both face and drums. I did it myself. It was very easy and didn't take more than about 1/2 an hour a wheel.
I find that if I just use the pressure washer and then dry the wheels, the brake dust is all gone. No brushes needed nor cleaning fluids. It really does make cleaning the wheels much, much easier as it saves a couple steps.
Here is what I did:
Pressure wash wheels
Used Sonax, scrubbed
Pressure washed wheels
Iron X, scrubbed
NanoSkinned wheels
Dried wheels really well and made sure no residue was left on any surface
Applied Opti Coat to entire wheel, including face, calipers and drums.
Left a nice shiny coat on the wheels and like I said before, cleaning them is a real breeze now!
Good luck!
This perplexes me, because on a vehicle that is the color of yours, you should have been able to tell a dramatic difference if the prep-work, i.e. polishing was performed and then the CQuartz was applied.
CQuartz Finest should have made the paint after polishing look like a deep mirror.
HUMP
Carolina Auto Image
Upstate, SC
www.carolinaautoimage.com
info@carolinaautoimage.com
FB and INSTAGRAM
HUMP
Carolina Auto Image
Upstate, SC
FB and INSTAGRAM
