Hit the rev limiter...
Reviving old thread, yesterday on a hot rolling start, I was too late shifting from 1st to 2nd, and the weirdest thing happened with the PDK, it felt like it hesitated, went into neutral, and than second gear. Needless to say that during that split second hesitation I was pegged on the rev limiter, it was really fast but I think I hit the 8500rpm, for sure it passed the 8000rpm mark.
So the question goes, at what RPM does the 991S Rev limiter engage, 7800, or 8500?
That is a bright spot of the PDK, you can manual shift even in auto mode!
The paddles aren't there for shifting. The car is perfectly capable of doing that all by itself, faster and better than any human driver ever could. Most likely they are there for the same reason as the redundant center console shifter- old familiar habits die hard.
Actually, that's why I chose the MF steering wheel over the sport steering wheel. I almost never use the toggles because the computer is smarter than me. I will occasionally use the toggles for a quick downshift in preparation for passing. I understand that the paddles can be "fun" but don't be delusion and think that you would be faster shifting manually. I'm pretty sure that Walter Rohl commented that on the track he leaves the PDK in auto. So fun doesn't always = faster.
It downshifts very fast but I still prefer to be in a lower gear before I try. Maybe it is habit and I rarely do it. My toggle use is at most 1% of the time. Toggles? Paddles? Who cares....I use neither. However, I do tend to leave the car in sport mode most of the time unless I'm just cruising on the highway.
No. PDK will not allow the downshift if the algorithm predicts an over-rev.
After reading the responses on this thread, I've been driving in sport mode without using the paddles in non-spirited driving. It is great to use in cold weather since it seems to shift early when the engine is cold and get more aggressive as the engine warms. You don't have to pay attention to oil temp and it's very intuitive. PDK is GREAT because you get what seems like two transmissions. Shift on your own when you like, or leave it to the computer. Thanks for the suggestion to use automatic mode more.
In response to an earlier post, I don't think you can count on an upshift before the rev limiter kicks in when shifting with the paddles while in automatic mode since PDK seems to stay in manual mode for 5 seconds or so after the last manual shift.
