Help on a 991 Exhaust Upgrade
Old 01-19-2013, 11:34 PM
  #31
rijowysock
rijowysock's Avatar
i dont see +50 from exhaust swap.. i guess the more important dyno is the baseline dyno... because it seems like the 423 is over adjusted, so the base probably shows 400?
Old 01-19-2013, 11:40 PM
  #32
Big Al HURT123
Big Al HURT123's Avatar
Were you able to see the videos. Help is appreciated. Truth is I'm just looking for better sound and little more power in more rangers. There is also an ecu mod done.
Old 01-20-2013, 03:51 AM
  #33
ScorpionT
ScorpionT's Avatar
Would need to see a baseline dyno, because rating something as crank horsepower is always a little.. odd. Would also need to see the correction factor used. Without those two elements the numbers are completely useless.
The transition on the modified headers is far from ideal, and it would be good to see the rest of their exhaust to get an idea of the actual work performed.
Old 01-20-2013, 09:00 PM
  #34
advantyper
advantyper's Avatar
Nice, do you have the Spasm on your car? your spoiler extended way higher then mine
Sounds nice
Old 08-27-2013, 02:08 AM
  #35
jmorgan911
jmorgan911's Avatar
Any word on the FVD exhaust?
Old 08-28-2013, 12:09 AM
  #36
advantyper
advantyper's Avatar
here is my 991s with FVD Sport Exhaust blasting down the from straight at Ridge Motorsport Park, my friend stood a bit too far behind the barriers, but the sound is much more aggressive in the car.
Old 08-28-2013, 08:47 AM
  #37
jmorgan911
jmorgan911's Avatar
Video is private
Old 02-19-2014, 12:07 AM
  #38
John D II
Basic Sponsor
John D II's Avatar
We just completed our 991 exhaust design - 100% T-304 stainless steel, manufatured by Speedtech in the USA. The total system weight with the two dual mufflers, tips and hardware is only 28 lbs. A full muffler bypass X-Pipe is also available.
Additionally, a center muffler delete X-Pipe is currently under development and will be completed later this week.
As with all of our X-cellerator line of exhausts, the system is modular and as such, the various 991 components are interchangable with each other, so that the owner is able to swap components to alter the sound level as desired...
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
Old 02-19-2014, 02:49 AM
  #39
DvidzBlk991
DvidzBlk991's Avatar
Originally Posted by porshanut
I test drove a '12 991S and a '13 991 back to back last week and had them both in sport mode. The S had PSE and the base didn't. I had an '11 CS with PSE so have some experience there. For some reason the S's PSE did not sound that much different from the normal mode. That being said, the 991's stock exhaust has really been upgraded. The base Carrera's 3.4 without PSE sounded really good! The 991 base sounded so good, I almost decided to go with that model. Then I realized in a month I would have wanted the Carrera S. Everyone on this forum raves about PSE, and I loved my '11 with PSE, but I am wondering if the Porsche exhaust on the 991 is really that different?
+1
I test drove a '14 S and a '14 Base 3.4. I wound up buying the Base. I actually preferred the sound of the base 3.4 exhaust under full acceleration to that of the S exhaust...The S however, I thought sounded better on start up...I drove both with PSE, I also found the Base PSE sounded much more different than normal mode than the S did...For me, i wound up skipping the PSE and just getting the regular exhaust for the base 3.4. The 3.4 doesn't sound like much on start up,,but in the 6-7k rpm range, the regular exhaust on the 3.4 IMO sounds amazing!
Old 02-19-2014, 09:03 PM
  #40
addysdaddy
addysdaddy's Avatar
I would like to agree with you - when trying to decide about the exhaust I drove a 4S with the PSE and frankly I was underwhelmed. The salesman keep flipping the switch on and off and there really wasn't an OMG kind of difference that could hear. Under heavy load both sounded great. On his recommendation I didn't option the PSE when I ordered the car and will wait and go the aftermarket route if I feel it's really needed. Felt waiting was the safest best since all options are still in play after taking delivery.
Old 02-19-2014, 11:41 PM
  #41
JamesKen
JamesKen's Avatar
They both sounded great under load because they are the same under heavy load. With PSE even if you don't push the button the valves open up under heavy load.
Old 02-20-2014, 02:27 PM
  #42
StudGarden
StudGarden's Avatar
Originally Posted by rijowysock
so i suggest remove the sides.. and get a small piece of pipe fabricated (or someone might make already (secondary bypass)..) and not only do you have a very wlld exhaust.. but lose a BUNCH of weight as well.
First of all thanks for the very informative post!
As to the above, what (if any) are the "disadvantages" of doing this? Does it make it Harley-esque loud all the time? Fuel economy/EEC issues? Cut into any tolerances?
Just seems almost too good to be true for how easy it is. They went nuts on the 991 to reduce weight, so I'd think 30-40+ lbs as many say would more than have to justify their existence or Porsche would have just done them all like that from the factory?
Old 02-20-2014, 11:31 PM
  #43
kitwetzler
kitwetzler's Avatar
It's ridonkulously droney for one. Sounds like an elephant farting directly into your ear. It is not bad once you get on it, but there are valves in the stock (and good aftermarket) exhausts for a reason!
Old 03-06-2014, 01:58 AM
  #44
wanderfalke
wanderfalke's Avatar
If one adds the PSE after delivery is it the same as the one installed at the factory including the switch gear on console.
Old 03-06-2014, 07:52 AM
  #45
rnl
rnl's Avatar
Yes
Sent from my iPhone using Rennlist
Quick Reply: Help on a 991 Exhaust Upgrade
