Installed Radar Detector on a 991 a problem
Social media has been manipulated before. Take a look at who's doing the successful videos. A lot of what I saw appeared to have some sort of corporate aspect to it or professional vid aspect and not much videos of the home pet on their account.
I think I would like to revisit this. You are saying with great certainty that is does not work based on a very old article that did not include any actual experimentation. The battery powered Lidar gun reads scattered reflections. Its output is limited.
He does not get into Laser diode based jammers which came out in 2006. The lack of information on Laser diode based devices points out how dated the old the article is.
My system is Laser Diode based (as are all the good systems). So I believe that direct transmission of a signal meant to confuse the lidar gun is easily possible.
Don't start saying the military wants to talk the people that can do that because it is a cop out. Guiding a missile and judging an object's speed is not the same thing. The goal of the device is to send out similar but conflicting signals which causes the processor to not be able to achieve a solution quickly. Sounds very doable to me. Does it work at every range, no. Is is technically feasible, I believe so.
If it was total BS there would be someone who tested it and found it to be total BS. I can not find that source so I believe you are wrong and the article that you use to debunk the technology is so dated it is useless and it has no experimentation to prove its theory.
Just go on youtube and look at some of the video testing. The jammers work very poorly if at all. I was gung ho to install such a system. Researched them all. In the end, I decided not to bother. The existing systems are a complete waste of money.
Well I have had Laser jammers (Lidatek and Laser Interceptors) on all my cars since 2001 and have been hit by laser numerous times and have never received a ticket. I have seen the confused faces of the LEOs as I pass them as they shake and stare at their laser guns. That's enough evidence for me that they work.
I have none, been lased several times between Miami and Montreal since my first V1 install in the late 1990s and also have never received a ticket.
What is a control test?: http://answers.yahoo.com/question/in...0000416AAxbnzf
