Fun Facts about the 991 (please contribute)
#241
Was not thinking of that when first reading this one. You are correct. Clamping the E brake onto nearly red-hot rotors will warp them and/or make impressions - either turns rotors into near-junk. Not a good idea for Porsches unless there was some sort of rotor temperature sensing scheme that would block the E brake turning on when the engine is turned off. That scheme would also need an attention getting light notifying you that the E brake is not set.
#242
such a helpful thread!
#243
Based on aero and speed.
rwbern (03-12-2023)
#247
Interesting. I have a 2018 C2S and that is certainly not the case. Does not need to be unlocked for me.
#248
It does on my '19. You can immediately relock the phone, but to get Carplay to connect, you have to unlock for a moment. Same is true on my wife's Q5. Now, we both have PINs and finger print security set up, so there may be a way around it without those things.
#251
On the topic of the raised spoiler , here’s a silly one...
If you manually lower the spoiler just slightly you can have the long brake light and the short integrated brake light come on together.
#253
Not to highjack the thread, but y'all might get a kick out of this: My wife and I were driving from Brenham, TX to Houston, TX Saturday night in pea soup like fog with the rear fog light activated. Before we got out of Brenham, we were pulled over by local police for a, "strange issue" with our brake lights. Of course the issue wound up being the rear fog light. After I explained what the officer was seeing, turning the rear fog light on and off three times with various brake light activations, I was being thanked for my time and patience and told to drive safely home. "Twenty-two years on the force and I've never seen anything like that" the cop said to me as he shook my hand and walked back to his cruiser. I've been using rear fog lights in bad weather conditions consistently since 1996... ...I always figured they were at least common knowledge to law enforcement.
#254
The frunk on the C4S/4WD models perfectly fits a 27.5" MTB tire, but not a 29". 2WD versions allows you to fit a 29".
vts_lake (06-04-2021)
#255
