Escort Radar Hardwire Help Please
Old 05-09-2012, 10:16 AM
991nuke
8th Gear
991nuke's Avatar
Thanks 'WCE' ..I've done at least 6 of these installs including the Escort SR-1 on my old boxster 's'. My only concern was that window post molding removal where I intend to run my wire up to my Escort 9500i.
P.S. lol,,,i already had the fuse cover off,,,,successfully
Old 05-09-2012, 11:20 AM
Carrera GT
Wordsmith
Carrera GT's Avatar
Originally Posted by 991nuke
I will be doing the same install this weekend, any problem getting the wire up to the mirror/radar unit? Is the window post molding just a 'pull off'?
I also read that if you did not get the smoking package that there might be an unused power source in the center console that was meant for the cigarette lighter. was thinking of getting my power there....any thoughts?
I think you'll need to check with the service manager at the local dealership to find a circuit that is energized with the ignition, but does not switch off when the engine is "off" because of the auto-stop feature.
If there simply is no such circuit, Valentine 1 offers the "BOB" which is basically an in-line capacitor to feed the radar detector for brief periods in cars with auto-stop.
Old 05-09-2012, 11:51 AM
991nuke
8th Gear
991nuke's Avatar
Engine "off" because of the auto-stop feature does not seem to effect accessories like radio so I'm hoping that's a good sign.
Old 05-09-2012, 12:03 PM
Carrera GT
Wordsmith
Carrera GT's Avatar
Auto-stop does interrupt power to the 12V outlets.
Old 05-09-2012, 01:45 PM
Mike in CA
Mike in CA's Avatar
I can't remember now the exact switched circuit I used in my Cayenne S, but it does in fact shut off with auto stop/start. I haven't gone searching for a new circuit to use since a) I'm not at risk while stopped and my V1 quickly reboots when this happens and b) in my driving, start/stop is pretty much irrelevant and I rarely use it.
Old 05-09-2012, 05:18 PM
Carrera GT
Wordsmith
Carrera GT's Avatar
It's certainly annoying when I drive around town. Once the car is in the middle of its auto-stop "sweet spot" it will shut the engine at every opportunity.
Anyway, it's tedious to try to hunt for a circuit that's live and doesn't die with auto-stop, so hopefully the service manager can get their sparky to figure it out from the schematics or whatever they have.
Old 05-09-2012, 09:33 PM
gota911
Newbies Hospitality Director
gota911's Avatar
How about turning auto stop "off?"
Old 05-11-2012, 09:53 PM
catchacab
catchacab's Avatar
Just turn off autostop
Old 05-11-2012, 10:05 PM
Carrera GT
Wordsmith
Carrera GT's Avatar
How did I miss that?! It's so obvious now you explain it.
Aargh. If I keep making mistakes like this, I'll probably end up trapped in a zoo, forced to live in front of gawking morons or just plain extinct!
Old 05-12-2012, 01:03 AM
SSST
SSST's Avatar
Originally Posted by GoTexas
Ok, since you're not an ATM dad, I will answer your question It's the super cup windshield mount from ebay.
Roll Tide! LOL!
I'm also married to an Aggie and both my sons are Aggies.
As to your OP, I have the same problem, but the escort powers itself down after 4 hours of inactivity. I just ignore it. Maybe I have a little Aggie in me after all.
Old 11-02-2012, 11:57 AM
limey940
limey940's Avatar
Dont click on the above link, its spam.
OK, basic question, what wire do i need and what do i need on the end to go into the fusebox/
On my 997.1 i went straight into the mirror dimming, i dont think thats possible on the 991.
can anyone do a remedial/101 step by step including the wire , ends etc?
thanks
Old 11-02-2012, 12:17 PM
HotLap
HotLap's Avatar
Hae you considered using the Blendmount and Invisicord? The blendmount bracket attaches to the mirror stalk and is nice anodize piece that is stealth and will hang the Escort right below the mirror. It has multiple adjustment points so you can get in perfect. I have this set up and have moved it between several new cars. Going to get the same thing for the 991 soon.
Old 11-02-2012, 12:45 PM
limey940
limey940's Avatar
I checked and they do not have a 911 product compatible with auto dimming mirrors.
looks like a nice product but i have auto dimming.
cheers
link
http://store.blendmount.com/blendmou...Questions=True
Old 11-05-2012, 04:02 PM
Detroit Shooter
Detroit Shooter's Avatar
Go Texas where did you get the connector you used in the fuse panel? Is that an escort piece or did you get it some where else?
Old 11-05-2012, 04:12 PM
Detroit Shooter
Invisicord looks like it back probes the connector for the self dimming rear view mirror? Is that correct and has anyone used it?
http://www.invisicord.com/install.html
Quick Reply: Escort Radar Hardwire Help Please
