C&D road test & comparison
Specs and Data
2012 Chevrolet Corvette Z06 vs. 2013 Nissan GT-R vs. 2012 Porsche 911 Carrera S
"This is the best 911 ever, which means it’s less like a 911 than ever and now just a fabulous sports car that happens to have its engine in the trunk. A bad thing?
Judging from the heated banter on our online forum, this is a subject upon which reasonable people (plus a few whackjobs) may disagree. You can see where we land by the voting. Porsche has done what all car companies attempt to do with the overhaul of an icon: fix shortcomings while preserving the essence. In the case of the highly idiosyncratic 911, these goals are somewhat at loggerheads. But, as it often does, Porsche strikes an attractive balance.
It may look like the old Carrera, which in many ways looks like all of the 911s that precede it, but the new Carrera is more comfortable and significantly quieter inside, thanks to better isolation from tire rumble. It has none of that spooky steering slackness under acceleration, when load transfers off the already lightly burdened front tires. And it shows less of the nervous hopping through corners that makes older 911s such white-knuckle entertainment.
This new car is wired to its aluminum/steel gunwales with motherboards, from its electrically assisted, bump-filtering power steering to its electronic shocks aided by the electronically controlled hydraulic anti-roll system to its electronically activated Sound Symposer cabin megaphone. Yet the Carrera feels the purest and most tactile of this lot.
If the steering doesn’t bobble over rough patches as it once did, it does have a distinct mechanical hardness and an animated liveliness, accurately conveying the strain of tires holding a firm line. We’ve heaped scorn on electric-power-steering gears from other manufacturers. Perhaps the key is to have perfect steering to start with when you tune a new system.
The 3.8-liter flat-six returned the best fuel economy and a 0-to-60 time of 3.6 seconds, answering any prod with a rowdy burst of kinetic energy and the sound of titanium-headed timpani we expect from a Porsche. It wasn’t fitted with the seven-speed manual, but the PDK switches gears with brevity and well-oiled efficiency. Still, we’d prefer the manual, and not just to save the additional $4080 for the PDK.
With the 991-series, the Carrera officially feels big, and it’s not just that the car no longer tippy-toes around on a truncated wheelbase as it once did. The windshield base moves forward about three inches at its center point, greatly deepening the dash. For old 911 hands, the visual effect is akin to what movie cinematographers call a “dolly zoom,” in which an object in focus (say, the steering wheel) stays fixed while everything else seems to pull away. Studded with buttons, the sloping center console distinctly recalls the much larger Panamera, as do the shared window switches (which are blank where the rear-window buttons would be).
If it’s no longer as intimate, the new Carrera is certainly comfortable, the optional power buckets offering many adjustments to supply orthopedic support to taste. We just wish it weren’t so flipping expensive. With the options, many of which we consider essential to replicating our experience, this test car crowds the base price of the 2012-model 911 Turbo at $138,450.
Porsches have never been everyman affordable, and if someday they are, we’ll complain that the brand is soiled. Meanwhile, the new 911 S, six-figure tag notwithstanding, plugs in right where the old one once did, casting its golden glow on the enthusiast sweet spot."
Comparing my 997.1 to a friend's 997.2, I was underwhelmed and wouldn't consider upgrading, although the increased mileage is something I'd like. But the 991? Maybe when you guys let your's go off lease, I'll have to test drive it and decide!
I have yet to read any positive comments from you on the 991. You obviously feel that your gt3 is threatened by an "ordinary" Carrera S.
in addition to the weight, the timed straight line run comparos are a bit skewed when you consider that the 991 has PDK, SC w/LC and PCCBs to lighten the load a tad. And, it costs over $10k more!
let us compare a manual 991S with iron against the same gt3. fair to say that the gt3 will walk away as the speed increases. yeah, these cars are not drag racers but it does matter.
Also, why does the availability of PDK on the S "skew" the results? Just because it's not available on the GT3 (yet) doesn't invalidate the fact that it makes a 991 S as faster or faster than a GT3 in a straight line. Besides, another post in this forum reports that R&T tested a manual 991 S and got a 0-60 time of 3.7. Haven't seen too many GT3 tests where they did any better than that. And remember that a 991 S has virtually matched 997.2 GT3 times on the Nurburgring.....
And 0-100/quarter-mile runs between the respective stick-equipped cars would be expected to result in discernible wins by the '3.
No doubt we will all find out soon. The new car is obviously a significant step forward in handling, but even if it is "as fast" as a 997.2 GT3, it's hard to imagine someone swapping the latter for the former - there is simply so much feedback specific to the GT3 experience, and that visceral experience is precisely what is desired by those who've opted for the '3.
Speaking only for myself, I would not buy a car without a stick, as it provides me the minimum level of interface which I crave with the machine. Perhaps neither car is "better" - just diverging yet targeted choices for widely varying enthusiasts. Something for everyone, as it were.
Given a choice between a $130K 991 and whats currently available, i'd strongly consider a 997.2GT3 but would need a DD too which i could buy with my $130K budget. Figure $95-100K for the Gt3 and $30-35K for a DD (Audi A3).
The N'ring times where the 991 C2S and 997.2GT3 being equal - are probably more to do with the 991's PDCC, PTV and longer wheelbase plus wider front end - than PDK (my amateurish guess).
No doubt PDK plus LC makes for an amazing 0-60 time. But I have used LC all of 3 times in over 14,000 miles - so who cares. But PDK does make for a fast 0-60 time.
However, I will say that the 991S has matched the gt3 times at the Ring, but that was one lap.
I am not concerned about how much time PCCBs may or may not shave off of any run, it is the fact that some tout the car's lightness relative to the gt3 when this 991 has PPCBs which saves 45 lbs. PCCBs certainly do not have less effect that what you saved in seats on your car. I will say I do find it humorous (this part is not directed at you Mike) when people go on and on about PAG shaving 88 lbs (or whatever) from the 991 as if it will change the handling dynamic of the car so much, but when faced with the 45 lb PCCB weight reduction in unsprung/rotating mass, PCCBs have little effect, in their opinion. Geez.. I thought I read somewhere how rotating/unsprung mass reduction is many times considered twice that when compared to static weight loss.
Relative to your GT car remark, a turbo is much faster and very nearly as close at the ring, but not nearly as much fun as a gt3. With that said, I'd likely vote 991S (optioned right) instead of the outgoing turbo, but not in place of my gt3.
End of the day I do not care at all for LC. Like others have said, Use it once, twice and then what's the point. Far too abusive on the drive train and it's not a drag car. PDK, well.. that's subjective. I don't care for it and my next gt3/RS won't have it, but I certainly will not discredit its capabilities.
0-60/62 is basically meaningless, imo. In-gear runs to 100 and beyond provide better data relative to HP.
The only part of my aforementioned post I would like to amend is calling PCCBs an acronym; user error.
