Your title is misleading. You said vents blocked then you said my solution to direct to other vents would not work as it was the flow, not the vents. Good luck.
so nothing I did would restore any kind of airflow to any vents.
I disconnected the battery and let the car sit for a couple minutes.
Fortunately I had an ice chest I remembered and I was able to save the chocolate which is the most important thing here.
When I started messing with it again I turned the AC off and just the fans on high and I still didn’t get any airflow but I left it like that because I was tired of messing with it.
Suddenly started blowing high speed just a ton of incredibly humid air.
I let it run until the air dry and the air conditioner again.
And now the air conditioner seems to be working normally.
edit: pulled codes top one does seem to coincide with cov problems
