10MPG in S+, 991.1S, normal?
Old 08-26-2024, 10:21 AM
Irfan
Irfan's Avatar
Default 10MPG in S+, 991.1S, normal?
Got my .1 in June with 18,800 miles, one owner and plugs were done last Sep at 18,400 miles. Prior to it was done at 15,600 miles in Aug of 2021. It was a Minnesota car from new (91 Octane), but it's crazy that I am getting 10-12MPG in S+, not even pushing her hard. Is it normal? I am in FL, she is drinking 93 octane.
Old 08-26-2024, 10:25 AM
MPawelek
MPawelek's Avatar
Are you doing your regular street driving in S+?
Old 08-26-2024, 10:46 AM
DC911S
DC911S's Avatar
I'm guessing your running the AC the whole time as well. I've found that here in the mid-Atlantic when I'm in S+ with AC on and driving it a bit hard at 90+.....she swallows the gas pretty quickly.
Old 08-26-2024, 11:09 AM
shammerman
shammerman's Avatar
If the PDK has been reprogrammed (emissions gate) it works out fine in street driving and is phenomenal in spirited back roads carving. No more only redline upshifts - only if pushed with pedal to the metal - otherwise upshifting at about 3,800 rpm.
Old 08-26-2024, 11:22 AM
Irfan
Irfan's Avatar
Mainly around town with no traffic.
Old 08-26-2024, 02:30 PM
mwjackson92
mwjackson92's Avatar
10mpg is pretty low. I was averaging 21mpg for the first 18 months I owned my car, but when I had PSE and Sport Chrono Package retrofitted I slipped down to 14mpg average. So definitely sucks down gas much more listening to that glorious note!
Old 08-26-2024, 02:33 PM
Irfan
Irfan's Avatar
Yes, got all that turned on, plus AC in FL heat.
Old 08-26-2024, 06:55 PM
Pavegeno928
Pavegeno928's Avatar
2014 991.S with power kit (50th Anniversary) Manual Transmission, sport chrono, PSE
No mods
a/c always on in SE Albama
106K miles
All regular/scheduled maintenance
City driving - 25 mpg - Sport Plus on
Highway driving - 31 mpg - normal mode
In Germany on Autobahn at 150 mph+ or running very, very hard in the mountain roads, worst I ever saw was 15 mpg.
Something is very wrong.
Dgags (08-26-2024)
Old 08-26-2024, 08:43 PM
Irfan
Irfan's Avatar
Originally Posted by Pavegeno928
2014 991.S with power kit (50th Anniversary) Manual Transmission, sport chromo, PSE
No mods
106K miles
Maybe it’s the gas, I am thinking. Drives fine. Always was serviced at Porsche, plus had PPI done as well. I will fill up at shell next few times, will report back. I was getting 15-18MPG when I bought it, but haven’t really looked it unlit yesterday.
Old 08-26-2024, 09:00 PM
Pavegeno928
Make sure you are using 93 from a name brand. I run a fuel treatment such as Techron or Seafoam every 3000-5000 miles. You might do one of these each refill a few times just to see if something is fouled up. Anything obvious like fuel smells from a leak or any odd smells from the exhaust? If you have an icarsoft or other diagnostic tool (even an auto zone shop will pull them normally), check the codes and perhaps there is something there. When the plugs were done, were the coil packs looked at/replaced?
If you bought it from a Porsche dealer make sure they did the two recalls on the 991.1. The first was a Heat Shield for the engine. The second is for a Fuel Tank Leakage Module. Below is a picture of the work order performed by a Porsche dealer for free.
Here’s a generic checklist: https://mechanicbase.com/driving/cau...r-gas-mileage/
Good Luck!
Old 08-26-2024, 10:37 PM
Irfan
Irfan's Avatar
Good Luck!
Thanks! Don’t see any recalls. I will call the dealership in Minnesota to see if that was taken care of. Also plugs and filter are new. What jumped out right away from the article is wheel alignment. Prior to my last fill up, just installed 15mm rear and 12mm front spacers. I think most likely the cause of the bad MPG. I will have to get the alignment checked.
Pavegeno928 (08-26-2024)
Old 08-26-2024, 10:40 PM
bkrantz
bkrantz's Avatar
Received 1,113 Likes on 670 Posts
What do the inside of your tail pipes look and feel like? Super-rich tuning would suck fuel and leave your pipes very sooty.
Old 08-26-2024, 10:45 PM
Irfan
Irfan's Avatar
Normal black residue.
Old 08-26-2024, 10:48 PM
Pavegeno928
Let us know what you find out! Good luck. Love the 991.1!
Old 08-27-2024, 09:08 AM
Bud Taylor
Bud Taylor's Avatar
Default Something is off
I drive in a spirited manner in Florida and S+ is always on...2012. The lowest Ive ever gotten is 18 to 20 and 30 on highway at 83mph is normal. MT on mine though perhaps pdk issue ?
Quick Reply: 10MPG in S+, 991.1S, normal?
