10MPG in S+, 991.1S, normal?
#46
A poll would be interesting ... how many folks drive around town in Sport+?
I used it a couple of times to make sure it worked - then to make sure the launch control process worked. After that it seemed more odd than anything else. Sport, sure ... Sport+ for the track.
IXLR8 (09-01-2024)
#47
Pdk vs manual and .1 vs. 2
I imagine the above would determine how much it is used. If I drove an automatic I would not want it holding gears longer. On a .2 also probably not as pronounced and the engine leans more on the turbo for performance. With a MT and 3rd radiator in the .1 the car runs 10 degrees cooler in S+ which means a potentially longer life for expensive gaskets and rubber.
IXLR8 (09-02-2024)
#53
Both. I’m at 106K miles on the original clutch and I have driven it very hard over the last ten years. Still smooth as hot butter. I switch between the 991 and the 911G.
#54
#55
Sport plus in manual is nothing like sport plus in PDK. In PKD sport plus holds gears much longer, doesn't downshift. Sport plus in manual is fantastic, zero turbo lag since you are almost 1 psig boost while stopped, obviously transmission shift however you like since you control gears, auto rev is super nice. I get around 19 mph flogging my car in sport 2 around town. in normal mode around town 21 mpg.
#56
Around town I see 14-15 normally with 6MT and occasional Sport mode
8-9 on track
8-9 on track
#57
#58
If I drive "spiritedly" on the street in sport mode I get about 12 mpg. About 27 to 30 on highway if driven conservatively in standard mode. About 8 mpg on the track in sport plus.
Irfan (09-15-2024)
#59
I've never gotten better than 13+-. I think that my C8 gets a little less.......I don't drive much but when I do, I work em out.
