Apex VS-5RS Wheels
#197
There should be no issue here as we have numerous customers running the 265/35-19 front tire with no issues and the 265/35-19 is about half an inch shorter in height than the 245/35-20 aiding fender liner clearance. When paired with the 325/30-19 rear tire it maintains the OEM ratio of the rear being 1.5% taller than the front. The VS-5RS 19x9.5"ET45 is currently sold out pending a potential offset adjustment but the new ML-10RT in 19x9.5"ET48 and 19x11.5"ET72 is now available for pre-order for 991's without front axle lift (FAL cars should use the 19x9"ET50 front wheel).
- Brandon
- Brandon
#198
Basic Sponsor
- Branodn
APEX Wheels - expert@apexwheels.com
Website - Blog - Instagram - Porsche Fitment Guides
#199
If you have a 991.1 C4S without front axle lift then 19x9.5"ET48 and 19x12"ET46 is perfect, pair it with 265/35-19 and 325/30-19 tire sizes. A 991.2 C4S should run the 19x12"ET63 with the same rear tire. A front axle lift equipped 991 Carrera, be it a .1 or .2 will need the 19x9"ET50 front wheel to ensure inner clearance.
- Branodn
Do you think the +46 is too aggressive?
Now I am confused, unless the physical width of the fender is wider on a .1, a +46 wheel actually sticks out more on a 991.1
#200
@Apex Wheels Scrolling up on this thread, I see there's a 991.2 4S on post 75 The poster is running 20x12ET47, which is the recommended size for the V5RS on your website.
Why is your ML10-RT recommended size different? Once I get this all cleared up, I'll place my order! Thanks!
#201
Basic Sponsor
The 12"ET63 is the OEM width and offset for a .2 GTS, we just put a 20mm wider tire on it when in a 19" diameter which helps the look a good bit. The fitment all comes down to the amount of camber on the back of the car. 20x12"ET47 with a 305/30-20 looks perfect on a .2 widebody at -2° of rear camber (seen here) whereas a 19x12"ET46 on a .2 C4S with a 325/30-19 (seen here) starts getting close to poking a bit. With the right camber values out back then 19x12"ET46 is a much more flush option but the 12"ET63 gives you freedom in your alignment values for what you want on the street or track, not what you need to make the fitment work. Heres how I would proceed if I was shopping for a .2 C4S.
Stock alignment to -1.8° of camber and street or track tires- 19x12"ET63, maybe a 5mm or 7mm spacer
-2° of rear camber and a street tire (fitment will be very flush or slightly poke) - 19x12"ET46
Aftermarket LCA's for more than -2.2° of rear camber and track tires - 19x12"ET46
- Brandon
- Brandon
#202
- Brandon
- Brandon
Pre-order coming shortly!
Speed2k (08-03-2024)
