Are there any other photos of this rim on a white Porsche? Thank you!!
There have been a few white Porsche on our VS-5RS shared in this thread, you can also look through our Wheel Gallery (link here) to see all of our Porsche photography on VS-5RS.
Has anyone ran the more aggressive 19x9.5 +45 for the fronts with 265/35/19 tires? I'm wondering if there's any rubbing?
There should be no issue here as we have numerous customers running the 265/35-19 front tire with no issues and the 265/35-19 is about half an inch shorter in height than the 245/35-20 aiding fender liner clearance. When paired with the 325/30-19 rear tire it maintains the OEM ratio of the rear being 1.5% taller than the front. The VS-5RS 19x9.5"ET45 is currently sold out pending a potential offset adjustment but the new ML-10RT in 19x9.5"ET48 and 19x11.5"ET72 is now available for pre-order for 991's without front axle lift (FAL cars should use the 19x9"ET50 front wheel).
