With PSE off, do the valves open with RPM?
The valves on the non-PSE S model open up around 3300 RPM. Does the PSE have any similar setup, or is it just open/shut depending on the switch setting?
Does anyone know for sure? I ask because I have a valved exhaust and I am trying to decide if I want to have the PSE switch programed.
Yep - they do open up at around 3300 rpm. I find it annoying at times => I want my PSE switch to be really faithful - off means off, but sadly only an ECU tune can address this methinks.
But at least I have the switch to keep the valves open all the time => for that purpose I think you definitely want the PSE programming
Catharpin (03-16-2023)
@shyamvenky Thanks for the reply. I already bought the switch, I just need to have it programed. I had heard you need to get a "code" to activate the button, is that for .2 only? I have seen some post on here they got it programed without a code.
Essentially the 991.1 S/4S has valves stock that open up at a certain rpm. The difference is that when you get the PSE exhaust (with the button) you can manually open the valves before it hits that 3/4k rpm mark and leave them open. It's very similar to those with the automatic wing, yes it goes up and down automatically, but you have a button to manually raise and lower it at will. Hope that makes sense.
I have a 991.1 C2S, without PSE, I can hear it open up as revs increase with some crackles and pops.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1056x1523/1a1fd470_53b6_47e5_bcf7_3d3174d09705_e7164d57f7b323947e1216826478592fbad616b2.jpeg)
desmotesta (03-17-2023)
Image doesn't apply to N/A engine. 991.1
Is the center section the same for non-PSE 991.1?
If you install and code the PSE button on a non-PSE 991.1 S/4S, the valves will operate just like on a PSE car. The only difference is the sound itself.
1st time I have heard this, have you seen this done? This would be ideal for me as I like the sound and would be great if I can open and close valves via a button
Catharpin (03-17-2023)
I have done this. I first had the dealer code the newly installed button with the existing non-PSE S muffler, and then installed the PSE muffler. It is a good way to make sure the coding was done correctly before disconnecting/modifying the vacuum lines to the PSE muffler. With open valves at lower RPM's you can definitely hear the difference in sound even with the standard muffler
tilac999 (03-18-2023)
