991.2 S ZunSport Grille Screens
deviated
Newly installed ZunSport Grille Screens in a Carrera 991.2S.
The simple installation took 15 minutes.
The screens sit just in front of the Porsche moveable plastic louvers on the base Carrera and the Carrera S.
What holds them in place?
Got it..... I just watched a video on installation.
I've had mine for over a year (no center grill screen.) Make certain after you install them there is no interference with the louver operation. Install securely, good quality.
I have been thinking about those for my 2017 991.2 GTS. Cost? are they easy to install and remove if desired? Also while they look good and I imagine they do a good job of keeping leaves and other debris out of the intake, do you remove them to clean dust and dirt out of the area?
I didn't do the middle one- you have to drill the plastic. And it would be hard to clean the slats behind it. The side ones pop on and off and are easy to remove if you need to clean behind them.
Not worth it IMO.
Not worth it IMO.
OMTarga4S (02-23-2023)
Hi everyone,
I'm considering adding these grills to my 991.2, but my car has ACC in the mid-section. Unfortunately, the grills don't come with a cutout for the ACC. Do you think installing the middle grill would interfere with the ACC functionality?
Thanks!
Thanks!
Hi everyone,
Thanks!
Thanks!
