991.2 GTS Steering wheel black inserts
Ist it possible to change the silver inserts into black ones?
I would also accept to not have the multifunctions buttons on the steering wheel because for the looks i like it clean like the gt3 and because the car is no daily driver i dont need them....is there any error massage if i simply deplug them?
sorry for the picture, i used it for a german partdealer, (schwarz = black)
Great idea. I'm not sure who in Porsche thought that tacky silver plastic inserts, that screams cheap hatchback from the early 2000s, was a good idea here. Will be interested to see if anyone has any solutions....
Yes, can be done by using multifunction controls from a macan. You should be able to delete them entirely but try unplugging them first to see if any errors pop up. You won’t be able to scroll through the Menus though as you don’t have a stalk on the wheel to do so like the non-mf cars.
I didn’t realize the Macan had black inserts! Suncoast has them, not sure what the actual part number is https://www.suncoastparts.com/product/SKU998BLK.html
95B-998-537 Switch Assembly $243.55 (includes both switches L&R)
95B-419-938-H-5Q0 Outer Cover $15.95 (lower insert)
Received 3,443 Likes
Very easy to do:
The following 2 users liked this post by Bob Z.:
AdamSanta85 (12-15-2021),
biggreek (12-15-2021)
Vinh Nguyen (12-15-2021)
polobai (12-15-2021)
Yellow is a lot bolder than Miami Blue, which is why I went a different way in this Spyder as compared to the Targa GTS. Since the pic though I changed the shift **** and added a 12'oclock marker.
