What’s causing this? (Rear tires)
Old 08-09-2022, 06:43 PM
911Raider
911Raider's Avatar
Default What’s causing this? (Rear tires)
My rear tires are wearing on the outside, the driver side more than the passenger. The alignment seems pretty good, but now I wonder.
Is this under inflation, alignment, camber? I check my tire pressures very regularly, but every gauge gives a different reading. I use the same gauge but perhaps it’s not calibrated correctly. It’s a digital gauge. Could quick starts and speedy cornering do this? I’ve had several long days of winding roads and getting after it pretty good, not sure if it was enough to do this, however.
Old 08-09-2022, 07:38 PM
Cuda911
Cuda911's Avatar
My vote is camber.
Old 08-09-2022, 08:02 PM
jeffleept
jeffleept's Avatar
Underinflation typically will wear both sides of a tire.
I agree with probable camber too. Based on your wear up the lateral rib you probably drive like it's a 911. May need more negative camber.
Old 08-09-2022, 08:10 PM
ipse dixit
ipse dixit's Avatar
Received 11,995 Likes on 5,229 Posts
Is this your first 911?
Old 08-09-2022, 08:24 PM
911Raider
911Raider's Avatar
Originally Posted by ipse dixit;[url=tel:18294653
18294653[/url]]Is this your first 911?
2nd, but only had the first one a year, have had this one a year. I’ve never had to buy tires, yet.
Old 08-10-2022, 12:48 AM
ipse dixit
ipse dixit's Avatar
What generation?
I am thinking that the rear wear pattern may be a result of Porsche torque vectoring, which was only introduced to non-turbo 911s beginning in the 991 generation.
(The 997.2 TT/TTS had torque vectoring as optional upgrade, but not the "regular" 997 911s)
Old 08-10-2022, 12:57 AM
911Raider
911Raider's Avatar
Originally Posted by ipse dixit;[url=tel:18295047
18295047[/url]]What generation?
991.1, 2014 911S
Old 08-10-2022, 01:47 AM
z168
z168's Avatar
Originally Posted by Cuda911
My vote is camber.
wouldnt the positive camber wear the outer edges of the tire first?
Old 08-10-2022, 10:58 AM
vanlieremead
vanlieremead's Avatar
With our alignments, the inside should be the one wearing, not the outside. We like our tires out at the bottom for corning when weight is being shifted. This leads to wear on the inside for straight line travel. I'd say there is an alignment issue as wear on the outside, unless the car has been continually corned hard, shouldn't be.
Old 08-10-2022, 11:18 AM
996scott
996scott's Avatar
yes, negative camber will wear the insides faster. Most of my 911s have had more negative camber set up and have usually worn the insides more.
Old 08-10-2022, 12:00 PM
Norge911
Norge911's Avatar
If you don’t do canyon driving at high speed, ie above speed limit nor track driving, auto cross, then ask dealer or alignment shop for 0.5 camber (lowest you can go). And zero toe. I.e. square set up.
this should give you 10,000 miles more on your tires.
Old 08-10-2022, 12:06 PM
Tommy L Garage
Tommy L Garage's Avatar
Its neither. Your pzero tires are dry-rotted and need to be replaced. Go with Ps4s
Old 08-10-2022, 12:34 PM
996scott
996scott's Avatar
that's possible, but why would dry rot cause excessive wear only on the outsides?
Old 08-10-2022, 02:00 PM
Joec500
Joec500's Avatar
Received 1,028 Likes on 612 Posts
Did someone at some point try to reverse rotate? i.e. swap tires from one side to another?
Old 08-10-2022, 06:43 PM
Southbranch
Southbranch's Avatar
Is it possible that the passenger side tire is a newer replacement?
Diagnosing tire wear:
Quick Reply: What’s causing this? (Rear tires)
