Brake service/squeal
Hi there. I'm a new member with a recently purchased 2012 991S Cab. Yes, I searched several forums but didn't find exactly the information I needed.
This car has all of the dealer service records. The brakes were replaced (rotors and pads) at 27k miles (I have 52k miles now). The fluid was also flushed recently at the dealer. At the most recent service, the pads measured at 7mm front and 5mm rear. *Sometimes* they squeal like mothers. I mean *loud,* embarrassing. I tried a few hard stops and it solved the problem for a bit, but it seems to come back intermittently. Since I don't have that much wear left on these pads, I want to fix this properly. I also should mention that the brakes stop pretty well, but they don't seem to be as good as my C7 Grand Sport, and maybe they should be.
My questions are:
1 - Are pads with more wear and less friction material left more likely to squeal? I've read that may be true
2 - The rotors have a slight lip but the wear indicators on the rotors indicate they are good. But, as you can see in the photo below, there seem to be concentric grooves, and I'm not sure if that's normal, and if it requires replacement. Can I reuse them for another cycle as long as they aren't warped?
3 - If I reuse the rotors, can I just deglaze them with emery cloth and clean them carefully?
3 - If I reuse the rotors, do I just need: pads, sensors, anti-squeal grease, and caliper bolts? Do I need to replace the anti-rattle clips or can I reuse them? Anything else?
As I mentioned, I want to do this properly, but it would good if I didn't have to replace the rotors unnecessarily. Any guidance is appreciated, as I'm new to these cars, though not new to brake jobs.
My questions are:
Brake squeal is normal on these, welcome to a 911. It actually says this in your owner's manual.
Your pads are well within service limits. If you have to replace parts, you can just do a pad slap (inclusive of single-use bolt replacement and the like) and a couple hard stops to bed them in and you'll be fine. To be clear, by "fine" I mean "exactly where you are right now."
For what it's worth, I just had the pads replaced by the dealer on a CPO car that had horrible squeal, even when the brakes weren't applied. They had around the same thickness left as yours. Dealer didn't replace the rotors. I'm on 27000 miles, 2017 S.
I would replace all the hardware as the other bits are cheap, although when I did my Boxster brakes I reused everything.
Does anyone take their 911 on long trips? Replacing brakes at 27K seems a little lite.
*I have red caliper envy*
Mine are like pink
Mine are like pink
My questions are:
My questions are:
My questions are:
My questions are:
Don't know why it posted twice.
My questions are:
My questions are:
Rotors have nothing to do with squeal
Oem pads correctly installed should never squeal. I use frozen rotors and oem pads for enthusiastic street no driving sound and stops quickly. Heavy dust. Others have said you can have no noise and less dust by running a non oem pad but I have not tried.
