I have the gt4 and am happy but can't speak to the numeric. Several people here have had both and seem to prefer the numeric. I wonder if thier use case is Street or Track.
I have the Numeric shifter and cables for street use. It is lightyears above the sloppy stock shifter that's made mostly of plastic. You can feel the Numeric is made from aluminum and steel.
We bought a manual transmission for a reason - driver interaction. The Numeric takes it to the next level. We are constantly interacting with the shifter.
Get their pedals too. Great grip and solid feel with no drilling.
I was planning on going the GT4 shifter route when I first got the 7MT. I had read and seen so many bad reviews about the 7MT over the years that I had almost no expectations. The OEM shifter seems so much nicer than I expected at first.
Just after a few drives I realized that although I could easily live with what others called the rubberiness and slop in the shifter, I simply could not deal with the vagueness and inaccuracy of the shifts in the top half of the pattern (1-3-5-7). Even when driving half spiritedly, at least with my average skills, I found the risk to do a money shift pretty high (due to the vagueness of Top gears).
From what I found out, the GT4 shifter was different only in length of shaft plus a more stiffer spring, but I was willing to give it a try.
While searching for a pre-owned GT4 shifter, I found a decent deal on a pre-owned Numeric and decided to give it a try.
The one I found had the 2mm stiffer spring, and after using this Numeric for about 500 miles, I am happy to report that I am glad I did not go with the Gt4 shifter. Although GT4 shifter would probably have been a worth while temporary upgrade, this numeric shifter is at another level in regards to accuracy and directness.
I dont track my car, no interested in Red-light-Grand-Prix (hence why I drive a slow NA GTS), and quick shifts aren't something I am looking for. What I do need is accurate upshifts and downshifts, especially when I have Sport Plus ON as even a slight inaccuracy near red line can result in an Over-Rev if you go anywhere near the "wrong" gear (with auto-blip ON) when driving aggressively through twisty roads.
If my less than track focus, less than street speed racer needs are met by the most aggressive option offered by Numeric, I suppose the Gt4 shifter would have been a let down for even a novice like me
I prefer the Numeric. It’s accurate tight and provides the appropriate feedback to help increase the situational awareness.
From an aesthetic and engineering perspective numeric is the way to go.
yes it’s a bit more expensive, but if it’s miles and smiles you’re after, you won’t regret it.
I run 1.5mm (softer spring) for an “OEM plus” feel.
Did you get the cables too?
It’s funny, I’m a big OEM+ guy, which is why I gravitated toward the GT4 shifter.
I just don’t know if it’ll be aggressive enough for me.
im a “do it once, do it right” type of person.
How much different does downshifting feel now?
Also, are the height and throws much shorter?
I’m still deciding if the cables are necessary for $500 more + a couple hours of labor.
I had a SSK on my E46 M3 and it was amazing, so I definitely want that special feeling in this car.
Hope this helps
That definitely helps! Did you get the cables as well? 1.5 inch or 2 inch? I’m definitely leaning toward numeric, just a really deciding if I need to spend the extra $500 plus labor for the cables
I have had both for 10's of thousands of street AND track driving. I even more recently added the cables too.
IMO SKIP the GT4 if the numeric shifter fits your budget. The GT4 shifter is built exactly like the stock shifter except for a shorter shaft for shift **** and an auto centering spring. It is a decent upgrade, but IMO the numeric shifter just takes it to the next level.
They have been working perfect for over 2 years. And from what i can see, they are of similar if not equal quality to the Numeric Racing ones. I know other guys in the 997 forums have used this same brand with great results as well.
The cables just brought the shifting to that next level. But they do introduce come gear whine into the cabin so be prepared for that. I personally like it.
I went through the same process, thought it was OK at first and now realizing the stock shifter does need to be improved .
Good to hear everyone saying the GT4 SSK isn’t worth the upgrade if you’re looking for something substantial.
I’m thinking Numeric 2” no cables.
I don’t want the additional noise.
Can always add them down the road.
Is yours 2”?
Thanks!
