My Wireless Charger for 991
Old 10-28-2021, 04:56 PM
  #46
ihbond
ihbond's Avatar
good question, I bought in Early May 2021, v3....some good comparisons of v2 v3 times...
Old 07-11-2022, 09:34 AM
  #47
Carben
2nd Gear
Carben's Avatar
Hi Brock,
This is a great improvement to the 991!
I live in Sweden and couldn’t order one off of your order page. Would be awesome if you could share the Stl file for me to print.
Thanks!
Carl
Old 07-11-2022, 11:57 AM
  #48
bds
bds's Avatar
Hi Brock - any ETA on a model for cars without the ashtray? This is making me consider making the ash tray swap...
Old 07-11-2022, 02:18 PM
  #49
brockbr
brockbr's Avatar
There's a few 991's in my club that lack the ashtray (so just the storage pocket) and I'd like to enlist one of them to allow me to use their cars as a mule The downside is knowing where the 12v power is underneath there. I'd have to assume that the ashtray lighter circuit is still very close by and it's just a matter of finding the plug in the harness.
That being said, I'll make more of an effort to get this done.
b.
  #50
brockbr
brockbr's Avatar
Originally Posted by Carben
Hi Brock,
Thanks!
Carl
I'm going to publish the stl file on a new thread today.
b.
The following 2 users liked this post by brockbr:
Carben (07-11-2022), myrr (07-11-2022)
Old 07-11-2022, 06:25 PM
  #51
SeymourButts
SeymourButts's Avatar
b.
Have you considered designing the housing with a slot at the back to allow the MagSafe cable to route through it and then run it to the center console to connect to the USB connector? When the console lid is closed you'll only see about 1/2" of the cable.
Old 07-12-2022, 12:48 PM
  #52
brockbr
brockbr's Avatar
Yes - I did consider that. And using a black cable would go a long way to making it nearly invisible. I mostly have challenged myself with designing the most simple and factory looking as possible. I may make an attempt with a through cable, but not before I finish my other new design. You can see it here: https://rennlist.com/forums/991/1308...l#post18244828
Old 07-12-2022, 02:33 PM
  #53
myrr
myrr's Avatar
Curious though if it was done like that.... you wouldn't be able to utilize wireless carplay as the charger would be occupying the USB connection instead of the dongle.
Old 07-12-2022, 09:23 PM
  #54
jbendaou
jbendaou's Avatar
Hi Brock… am trying to order using the link you shared through ApplePay but nothing happens. It says payment failed. (No it’s not my credit card)
Are you still taking g orders, can others confirm ordering recently?
Old 07-13-2022, 10:30 AM
  #55
brockbr
brockbr's Avatar
Hi Jalil,
It appears to have processed correctly, so I *do* have an order for you on the printer as I type.
b.
jbendaou (07-13-2022)
Old 07-13-2022, 10:31 AM
  #56
brockbr
brockbr's Avatar
More pics of the process (for those that like to see it...)
Old 07-13-2022, 12:02 PM
  #57
jbendaou
jbendaou's Avatar
Thanks. I tried a few times and it seems it went through. Really excited for this. Thank you
Old 07-13-2022, 02:52 PM
  #58
B Russ
B Russ's Avatar
This an option for us Androiders?
Old 07-13-2022, 04:20 PM
  #59
brockbr
brockbr's Avatar
This is specially for an iPhone with a MagSafe charger, but, I have been experimenting with a few wireless Android chargers. The problem (like many things android) is there isn't a lot of standardization, nor is there a lot of support for magnetic wireless charging. Designing a clean solution for 1 android device / form factor literally only covers a small percentage of the market, which most definitely isn't cost effective for a mass-produced piece.
I will gladly work directly with someone if they'd like to develop one for their device. However - the cost and time associated with a part like that are usually prohibitively expensive. For example, I figure I could modify one of my base designs and build a couple of prototypes inside of about 4 hours of work. Not counting prior design time, material costs or machine time (all of which gets expended in an effort like this), you're at a few hundred dollars (~$500+) just to have a prototype. Not exactly profitable use of time.
b.
Old 07-13-2022, 06:07 PM
  #60
Mr. Big
Mr. Big's Avatar
The Carlinkit dongle has a USB port that you can use to power the MagSafe charger.
Quick Reply: My Wireless Charger for 991
