Best way to launch a 991.2 7MT?
Here is what works for me in my 991.2 carrera t 7mt (1.9X 60 ft on Pirelli street tires). Turn traction control completely off, leave the suspension on normal, put the car in sport plus (not sure if this helps, but why not) and slip the clutch from around 2000 rpm. Let the clutch out too fast and it’s wheel hop city-but slip it easily enough and it’s been solid for me.
The following 3 users liked this post by polobai:
Where did I say that I bought the car just taking it drag racing? I didn't, so please stop assuming and putting words into my mouth.
Lots of high end cars are designed to go around turns, but they're still quick off the line. There's no reason the 911 shouldn't be as well. It's likely that a software fix could remedy this.
For the price and reputation the car has, it should be good at everything. It shouldn't lose off the line to an old Cayman.
This thread isn't for making excuses for the car's shortcomings. It's for discussing workarounds for this obvious flaw.
You're frustrated because you spent all this money on a car and can't drive it like it's a Camaro, and you're expecting a forum to magically come up with a "software fix" for you?
I was just trying to gently suggest you're in for some heavy disappointment. Not everyone views this as a flaw, probably because most people in this demographic grew out of light to light racing 20 years ago.
Isn't the Turbo S about the quickest gas powered car off the line? Seems like that's about as good as it gets for a "haha stoplight go brr" kind of car.
Isn't the Turbo S only available in PDK?
I'll say it again and maybe you won't get your feelings hurt this time. The manual 911 is severely compromised from a performance perspective. Porsche only offers their cars in manual because the enthusiasts demand them, for reasons other than raw performance. Otherwise they'd do what virtually every other performance manufacturer has decided to do and move away from them.
Maybe someone smarter than me could begin to explain why the manual cars induce "wheel hop", but my guess is the power available in these cars these days is just too much for the transmission components to cope with. Maybe your "fix" is software-related... but it would just lead to breaking things. Does the 991.1 suffer from the same problem? Maybe it's just an inherent engineering flaw with the rear-engine layout. Someone knows, but not me. It doesn't bother me because I don't need to beat G35 sedans with peeling tint off the line at stoplights.
Just learn to love the other things the car is good at, or get one with a PDK. Or another Cayman.
edit- I found a relevant thread where this topic has come up before; these cars are just not meant to be launched hard and can result in a very expensive lesson:
https://rennlist.com/forums/991/1234...ment-cost.html
I'm just trying to save you from yourself.
The following 2 users liked this post by manifold danger:
bh1cqx (07-22-2021),
George from MD (08-20-2021)
The wheel hop is partly from TC intervening at the 1st sign of loss of traction. Turning TC off will allow the wheel to spin more readily. Experimentally it does make a difference.
What's the quickest way to launch a 991.2 7MT?
If I launch my car from the two step limiter (which is around 4000rpm), it results in a tremendous amount of wheel hop. My old Cayman S did the same thing from a 4000rpm launch, but it also allowed me to launch from a higher RPM. When I launched that car from 5500rpm I would get a little wheel spin, no hop, and a nice launch.
If I launch from around 2000rpm, the car will take off without wheel hop, but not as fast as I'd like it to.
Has anyone found a good method?
Or are you saying that people who enjoy a fast launch aren't grown up?
Listen my guy, you're missing the point of the thread. I really don't care how you use your 911. If I want my 7MT to be quicker off the line, then that's my prerogative. If that doesn't interest you, then please don't clutter up this thread.
what 0-60 are you shooting for? what's your best so far?
i did not want to harm my car so i feathered it in and as soon as it was fully engaged gave it the beans. my best dragy valid time was 5.23 at 99 degrees F 1181ft asl DA 4237ft
Road and Track in 02/2012 got a 3.5 in a PDK 991 CS
M
Man, you're this close to understanding the point of this thread. I want to actually find out what the limitation(s) are and if it can be remedied. If it's just a software fix, that probably isn't difficult. If it requires an upgraded clutch as well, then so be it. We're not in uncharted territory, there are plenty of MT cars on the road today that can get off the line quickly.
Anyway, sure then. You'll get someone in here to chime in eventually that their APR stage 15 tune and greddy engine mounts solved the wheel hop problem. What I'm trying to do is save you the cost of all that plus a new clutch by suggesting you bought the wrong car for your intended purposes.
But millennials have to experience things directly for it to sink in, so... good luck?
Also since I'm feeling generous and would like to maintain that I'm still here to help, maybe this can help you reach your fullest potential at a stoplight: https://www.dscsport.com/
In theory, it should help with the wheel hop. At a minimum, most people agree it's a great, low-risk, low-cost mod.
OP, do you have Sports Chrono in your car?
My question behind is does the rpm limit when you take off increases if your are in Sport or Sport+ compared to normal mode? (I don’t think the rpm limit would change but it’s more for my personal knowledge). I think the rpm limit is to protect components.
I am sure Porsche engineers have a procedure to launch a MT 991 when they need to homologate official numbers for 0-60mph times (someone mentioned deactivating TC which is a good thing). The thing I don’t know is do they homologate the absolute best time they manage to get during homologation or do they take some sort of average. If it’s the former, it means it would probably not be possible to launch the car to consistently get the best launches.
circuiticon (07-22-2021)
The following 2 users liked this post by polobai:
circuiticon (07-22-2021),
enzotcat (07-22-2021)
