Best way to launch a 991.2 7MT?
#31
Anyway, sure then. You'll get someone in here to chime in eventually that their APR stage 15 tune and greddy engine mounts solved the wheel hop problem. What I'm trying to do is save you the cost of all that plus a new clutch by suggesting you bought the wrong car for your intended purposes.
If the problem is solved by a quick engine flash and/or engine mounts, then I'll gladly spend the money on them. No need to "save" me the cost of everything. I'm not sure why you care how I spend my money.
But millennials have to experience things directly for it to sink in, so... good luck?
Also since I'm feeling generous and would like to maintain that I'm still here to help, maybe this can help you reach your fullest potential at a stoplight: https://www.dscsport.com/
In theory, it should help with the wheel hop. At a minimum, most people agree it's a great, low-risk, low-cost mod.
I've used the DSC in other cars on track, and while it can help for certain things, I never noticed it helping off the line. BTW, an ecu flash or engine mounts are around the same cost as these, so clearly this isn't about saving me money. Seems like you just like telling people what to do.
#32
Negative
From what I've read on the forums, it's still a ~4K limit, even for those who have SC.
As for component protection, I'm just skeptical of that answer. Realistically, the PDK and 7MT cars are using almost the same components. Even the transmissions are the same internally, or so I've read. I have a hard time believing that you can launch a PDK from 6000rpm 50 times in a row without issue, but a 7MT (which is basically a modified version of the PDK trans) can't take the abuse. Are they sandbagging the 7MT to make the PDK look quicker? Or to limit potential damage from a botched launch (rather than the controlled, perfect launch of the PDK)? Maybe they are trying to reduce potential warranty issues?
The bottom line is that other MT RWD Porsches have been able to launch well in the past, and they weren't limited to 4000rpm. I'm willing to bet that without the 4k limit these cars would launch better (perhaps at the cost of a shortened clutch life).
Interesting point.
My question behind is does the rpm limit when you take off increases if your are in Sport or Sport+ compared to normal mode? (I don’t think the rpm limit would change but it’s more for my personal knowledge). I think the rpm limit is to protect components.
I am sure Porsche engineers have a procedure to launch a MT 991 when they need to homologate official numbers for 0-60mph times (someone mentioned deactivating TC which is a good thing). The thing I don’t know is do they homologate the absolute best time they manage to get during homologation or do they take some sort of average. If it’s the former, it means it would probably not be possible to launch the car to consistently get the best launches.
#33
Seems like you're gonna keep going until you hear what you want. I'll probably keep responding too until mods come in and delete all our posts. As much of an ******* you think I am right now, it's been what, 36 hours or so? On a forum dedicated to 911 enthusiasts... and you still haven't gotten a satisfactory response.
I'm not the only one saying this. Chances are diminishing that anyone is going to come along and save the day. Sooner or later you'll arrive at the same conclusion; the manual transmission in the 991 isn't as good as the one in the 981, and never will be- because that's a fact. You don't want to get into why that's a fact because it's "not the point of the thread"... but that still doesn't change that it's a fact... that's sort of how facts work.
Sorry you had to buy the car before you figured that out... in all seriousness, I actually am. The car just isn't good at being a drag car, despite what the magazines will tell you. It's not fun to launch the car and I personally feel like it's going to break every time I sort of do it. At the very least it's inconsistent- and I do have a DSC controller and I think it helped that's why I suggested it. I'm glad I don't like drag racing any more- if I did I swear I would buy another car. I sincerely hope you can find a way to enjoy it and do whatever you want with it and despite what you think I was actually trying to help. This is just my personal way of trying to save you the effort. It clearly was ineffective but whatever, it's a forum what else is there to talk about?
Most people actually don't care the car isn't great to launch because they don't use the car that way, as you're discovering. I'm not telling you what to do, I was trying to save you time by giving you straight answers based on experience and you got all snippy. You don't want to listen so I called you a millennial. I don't care if you actually are or aren't, seemed like a fit because I hear them say "my guy" all the time. I didn't know people my age talked like that. Seems weird.
Do you put a lot of product in your hair? Do you vape? Do you listen to skrillex a lot?
Rockerchief (07-26-2021)
#34
But yeah, I'm not convinced that anything other than slipping the clutch somewhat on launch with TC disabled will do a whole lot. I've done it once or twice; it definitely smooths things out and you launch pretty damned hard. That said, given that I'm pushing 550+ hp I'm not all that anxious to do it and burn out my clutch in the process. I'll disagree a little with the 981 vs 991.2 transmission - I actually don't have too many complaints about the 991.2 7MT as-is from the factory, when I compare it to the 981 GTS I had, but then again maybe I have lower standards for that, or maybe I just like notchy medium-throw shifts, I dunno. In practice on the track, I'm rarely shifting outside of the 3/4/5 gears anyway (and only seldom into 5th because you can hit 140mph in 4th gear), and with the torque I have, I can choose to be somewhat lazy about when to shift, although I will definitely downshift if I'm going to be lugging around 3k RPM.
#36
I believe that when PSM (traction control) is turned off (deactivated), it will temporarily activate if it senses one wheel spinning.
#37
Well, while stopped in neutral, the turbos really aren't spooled up. One could argue that the 3.0T has less torque at 5K RPM in neutral than a .1S simply because the engine is smaller. I have a feeling that's not the issue.
#38
OP, my personal experience is all in how you feather then release the clutch. Practice practice practice.
To all others, sorry... Not sorry. Get an effing life, mind your business and stop pestering the OP. This is a Porsche 911 forum. To hell with you and your stupid opinions that are not helpful and irrelevant to the topic. It's his car, he paid for it, let him do what he wants instead of debating him. Too much time being keyboard warriors. Go drive your cars and break the tires loose.
Seems like the common denominator in multiple threads is the same one or two people talking smack and debating for the sake of debating. I feel sorry for the people who have to live around this type. What a nightmare.
The following 2 users liked this post by 911dude41:
Bulldawgfan1000 (10-25-2021),
circuiticon (08-21-2021)
#39
Also the 3L turbo engines develop peak torque beginning at 1.7k RPM and hold it over a broad range. The 991.2 develops more power and torque at lower displacement in comparison to similar 991.1 models, it's faster.
OP is free to launch his car however he wants, agree to disagree.
#40
Have you played with tire pressures at all? I would think if you lowered the tire pressure in the back some it might help.
FWIW - I had tire hop on my Cayman MT (gone) and it could get dicey pulling out into traffic. Had to wait for a grandma sized hole.
#42
If you look up the numbers, you'll see that the .1 engines develop peak torque at a much higher RPM, around 5k and the torque numbers are significantly less than the 3L turbo.
#43
this is the graph from the dragy of the best time i got in the 991.1S 7MT. i was being pretty gentile and feathering in the clutch at ~2000-2500 rpms.
i'd love to see similar graphs from a 991.2 PDK with and without launch control.
![](http://www.fischetti.com/dragy991best.jpg)
#44
'til then, here's a rennlist-hosted copy.
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/668x1087/image_d276315b0892c5641c9736e6b8aef8006484f6a7.png)
#45
Why don't you just buy a Camaro instead of arguing with everyone who tries to give you honest advice?
