Smog, PIWIS and now VarioCam Plus
Note: I may need to cross-post this on a the 998 forum as well as their cars are older and may have more experience dealing with smog...
I've posted previously about my difficulties in getting the last sensor into a readiness state for smog. It's the o2 sensor. This past week, a fellow porsche-aholic allowed me to utilize his PIWIS to see I could dig in further.
When plugged into the PIWIS, it actually shows the o2 sensor in a ready state (plug my iCarSoft back in, and it shows not ready, also plugged in another generic OBD2 ready and it also shows o2 is not ready). After poking around for a bit I found a couple of things. Not sure if these are clues to help with resolving this saga though. So any insight is appreciated.
I found 2 fault codes with the PIWIS (again nothing on my iCarSoft):
P1672 Engine compartment purge fan 2: electrical fault (limit exceeded)
P2271 o2 sensor signal biased/stuck rich, bank 1 sensor 2 (limit exceeded)
Interesting enough, when checking one of the settings for readiniess, I got a "sad face" for VarioCam PLUS. (The rest of the screen, I got happy faces: misfire detection, mixture adaptation, other emissions-relavant component, catalytic converter monitoring, tank vent/tank tightness, oxygen sensors, oxygen sensor heater -- all happy faces)
I haven't found much reference to my P2271 error code on REnnlist or the interwebs.
TIA!
TIA!
Many scanners report such latched codes as "intermittent" or "stored". I know my Autel unit will discern between active, intermittent, and old, at least on my e39.
If you clear the faults, you will also clear all of your OBD monitors, and then you'll have to drive around (or use a tool) to force them back into the ready state.
I can't just reset the specific code? I'm not a fan of resetting everything and going back to zero. Though the hardest codes to get into readiness was the evap and o2. At least I got the evap one set.
I haven't had a chance to muck around with it lately to see if I can just reset the P2271 fault code.
