Centerlock cleaning
Centerlock cleaning
How many of you with centerlock wheels clean all the optimal paste off every time you remove the wheel? Do you A. Reapply paste over old. B. Clean it all off the lock and wheel and reapply fresh. or C. Wait till the buildup gets dryer up then clean and apply fresh.
Just wondering since this stuff is a PIA to get off and seems to get everywhere. I think I have it in my eyebrows by now.
I usually just reapply a bit of grease to the threads and then once every 12-18 months I strip them clean and re-grease per spec. I just got done doing this for 4 cars with CLs -- WD40 is your friend for cleaning the old grease off the nut!
I just clean off the old stuff and apply new. If they look dirty, or I accidentally drop it on the floor then they get a full cleaning. If they do not come off as one unit, they get cleaned.
But really how often are you even removing them? I have 2 sets of wheels, and new brake pads. So really it's just for wheel swaps, and since I hate doing that (need to ask the wife for help on the brake pedal) it's really only a couple of times a year.
Yesterday, I had an AX and it was pouring out all day, so the CUP2's are out, and the PS4S needs to go on. I defended to just stay home instead of swapping wheels.
I'm removing them after every DE to do a fluid flush, so about 4-5 times a year. Car is a 18 and I don't know if the original owner ever cleaned them. I did a pretty thorough job of it the first time I took them off this year. Oh by the way, a cutting board and a cabinet clamp from HD takes the wife out of the brake peddle equation. lol
While I used to do a fluid flush after every couple of DE days, I got a electronic fluid sensor, and there is absolutely no need to a flush after doing a few DE's. Honestly, I would do it annually, or after a pad change and that's about it. But if it makes you feel good to do so, then do it. I also change my trans & diff fluid every year. Porsche says you only have to do it at 100kmi.
markk222 (06-14-2021)
I do a fluid flush once a year, and usually do that as part of winter maintenance and inspection.
FWIW, hydraulic fluid never goes "bad (if the system is sealed)". It does not really were out, it just collects moisture. That's the measure I use for flushing fluid, but as I said, I also do it every year anyway.
Yes, after a fluid change I added some water and swirled it around, then tested. This was more a test to make sure my tester worked. I added quite a bit of water, and the fluid tester said it was time to change it.
