PIWIS III clone, anyone tried this?
Seems like you can get a PIWIS III "clone" at https://www.obd2tool.com/goods-10430...50-Laptop.html
As with anything, I'm a little concerned about getting scammed out of a little over $1k, but it seems like if this works it's worth my money. Anyone on the forums tried it? @love2020 or @rbrunelle - is this where you obtained yours?
enzotcat (05-07-2021)
Well, the turnkey solution certainly works. It arrived much faster than expected, contents are a PIWIS III dongle, USB cable, Lenovo T450 laptop with v38 and v39 software installed. Looks like it is in development mode because a bunch of German comes up along with English text. It connects to my 991.2 successfully and runs diagnostics successfully, so at least as far as that is concerned, it works. As to adaptations and such - I have not tried it at all. I need to ping the people who sold it to me and ask them if (a) I can take it out of development mode, and (b) I can connect it to a network and get updates downloaded online.
Agreed entirely. More interested to see if it can connect as far as certain adaptations are concerned - again just an academic exercise because I don’t really plan on using it for that at the moment, but I believe that these need to the system to be online. More useful for things like putting the parking brakes into service position, etc. and for better diagnostic scanning of faults. For example, I discovered a couple of faults that were a result of switching out the PASM module - totally benign, but didn’t show up with a cheapo OBD scanner. And naturally because I’m still dealing with the P24D6 thing I wanted to see if I could get more information from the system by using PIWIS. For that I have to wait until I induce the fault again.
What I would like to know is: For the Auto Stop/Start Switch (991.2), Can you change the selection in the software from "Active at Start-up" to "Last Position at Start-up" or "Disabled at Start-up" ?
Crap, I would pay a few hundred buck to get that changed! The 2 closest Porsche dealer will not do it, stating some EPA rule, and I rather not add the "T-Design" aftermarket module under the airbag if its a simple "Check Box" selection that already exists in the cars software.
In the Coding programming, you can find the coding value of 642 - START/STOP FUNCTION. It has an “installed”/“changed” column, and if you click on the “installed” it seems like you can make it look like it is *not* installed. And then I’d imagine you would write that coding out to the vehicle. So yes, it looks like you can, in fact, do that. Maybe something an Indy shop could do for you.
See START/STOP function highlighted. Note the no check mark in the “Installed” column, and the pencil in the “Changed” column - that’s because I clicked on it and changed the value. I *assume* this would write the changed value out to the car and disable the start/stop function, but I am honestly not about to test it out on my car.
@enzotcat - Many thanks for looking into my Auto Stop/Start coding question. I am a little confused by the statements suggesting "deleting" the functionality. Maybe I am miss-interpreting your words, yet my understanding was that the software already had the options of how the AS/S system should behave at Vehicle Start-Up.
I pulled the following from another thread, where they talk about using a PIWIS 3 in "Engineering Mode" to make the selection.........
Originally Posted by KINGSRULE View Post
Thank you but I should have clarified I don't want to press any button when I start the car to have auto s/s off
From what i can gather with the Porsche PIWIS u can program auto s/s:
Always ON
Always OFF
Remember last setting
But I haven't confirmed that it has/can be done on US cars....
Always ON
Always OFF
Definitely can be done on US cars. Need a PIWIS 3 in engineering mode so the dealer will not do it.
I can do it in a few minutes. Here is a picture of the screen taken from a 971 gateway module in engineering mode, manual programing area.
as you can see Stop prohibition is a selectable option.
