odd PDK behavior
Occasionally, maybe 1-2x monthly, my pdk will shift into 2nd gear from reverse and get "stuck" in that gear. Clicking the paddles up or down does not do anything. If I stop, shift to neutral or park, and back in drive, it will get back into 1 and shift normally. No other strange behavior, shifts completely normally otherwise. Brought to dealer, no codes stored and "could not replicate." I have a fidelity plat warranty so not worried in the long run, but wondering if anyone else has experienced similar behavior.
have u tried resetting the PDK?
edirtaynine (03-11-2021)
shammerman (03-11-2021)
I tried the "reset" method via the link above.... or atleast what was listed on the first post of that thread (the 3 min interval, a/c off then on). It may be placebo... but I think the 1-->2 shift is a little smoother? Idk, I'll keep you posted if the R-->2 gear change still happens.
I have the same PDK issue since I've bought the car three years ago. Also happens 1-2 a month and usually when the car is at operating temperatures. It seems to happen more often after I change the gears manually with the paddles. The issue also occurs when I start the car after a drive, PDK is stuck in 2nd gear and will only change to 1st after setting it to R/N/P. The dealership couln't find any code, had never heard of this issue and couldn't replicate it. This post is actually the first time I've read someone is having the same issue!
My car is a 991.1 4S, MY03.2014
Huh? It's pretty clearly listed in my signature below. I would suggest you look at that.
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/980x2000/screenshot_20210311_102018_chrome_6c8d659dae52f9955b7ac049ae82b0e09113cf7a.jpg)
yeah mobile browser doesnt show sigs
