Neutral by paddles??
Old 01-12-2021, 04:41 PM
B Russ
B Russ's Avatar
Default Neutral by paddles??
Did I read somewhere you can get into neutral by holding both paddles?? Is this an actual thing??
Old 01-12-2021, 04:44 PM
afk
afk's Avatar
yes - pull both back
Old 01-12-2021, 04:46 PM
darylbowden
darylbowden's Avatar
Yes, but only if you have the true paddles (not the weird things on the standard wheels) and it needs to be programmed by the dealer to enable this if the car didn't originally come with the paddled wheel.
Fullyield (01-13-2021)
Old 01-12-2021, 04:50 PM
Al.Fresco
Al.Fresco's Avatar
No need to hold them. Just pull both and release. If moving, pull either paddle to go back into gear. If stopped, need to be on brake when you hit up shift paddle to re-engage gear.
The following 2 users liked this post by Al.Fresco:
991.1 Guy (01-12-2021), tourenwagen (01-15-2021)
Old 01-12-2021, 04:58 PM
Mark993TT
Mark993TT's Avatar
+1
Porsche dealer wasn’t aware of this “feature” when I got my car delivered. I must have read it somewhere on this forum. ;-)
Old 01-12-2021, 05:05 PM
B Russ
B Russ's Avatar
Im going for alignment check Saturday, I will check with my dealer to see if its enabled. I dont have any goodies in my wheel so I guess its a standard wheel. Of course Ill check Friday
Old 01-12-2021, 05:21 PM
barncobob
barncobob's Avatar
im skeptical of doing something like that, do it in wrong sequence and the PDK might not agree
Old 01-12-2021, 05:25 PM
Al.Fresco
Al.Fresco's Avatar
Worst case is you either up shift or down shift one gear if your coordination is off. Can’t hurt it.
Old 01-12-2021, 05:30 PM
barncobob
barncobob's Avatar
mines out of warranty
Old 01-12-2021, 05:57 PM
asellus
asellus's Avatar
Received 2,060 Likes on 1,277 Posts
Just pull back on both paddles simultaneously, just like how you would command a down or an up shift.. except at the same time. It will pull the clutches and you'll be coasting. Pull either paddle when you want to go back in gear.
As mentioned, worst case scenario, you instead shift gears.
Nothing to do with warranty.
shammerman (01-12-2021)
Old 01-12-2021, 06:06 PM
darylbowden
Exactly. PDK won't let you overrev. No harm in it at all.
Old 01-12-2021, 06:19 PM
991.1 Guy
991.1 Guy's Avatar
I use this feature all the time. It replicates what you would do with a manual. The PDK has a learning curve to get the most out of it. It is not an automatic.
Old 01-12-2021, 06:21 PM
asellus
asellus's Avatar
Out of curiosity, what do you use it for so often?
Old 01-12-2021, 06:25 PM
991.1 Guy
991.1 Guy's Avatar
every time I roll to a stop light from 4th or 5th gear.
Old 01-12-2021, 06:26 PM
asellus
asellus's Avatar
What does this gain you?
Quick Reply: Neutral by paddles??
