Neutral by paddles??
Old 01-13-2021, 01:37 PM
  #31
Muu83
Muu83's Avatar
I thought the point was to clutch kick the car to get it sliding, or be able to dump the clutch for a smokey pull away rather than triggering launch control, aka hoon mode
Old 01-13-2021, 03:32 PM
  #32
Mark993TT
Mark993TT's Avatar
That only works with the GT3 PDK-S ...
The following 2 users liked this post by Mark993TT:
9ONCE (01-14-2021), phx991 (01-21-2021)
Old 01-13-2021, 07:00 PM
  #33
HkPlinker
HkPlinker's Avatar
Originally Posted by B Russ
Im going for alignment check Saturday, I will check with my dealer to see if its enabled. I dont have any goodies in my wheel so I guess its a standard wheel. Of course Ill check Friday
Old 01-13-2021, 07:08 PM
  #34
fastforddriver
fastforddriver's Avatar
I use it all the time on my 991.2 Targa GTS. I coast down to a stop in neutral like I would in a clutch car.
Old 01-13-2021, 07:20 PM
  #35
B Russ
B Russ's Avatar
That's the wheel I have
Old 01-13-2021, 10:15 PM
  #36
afk
afk's Avatar
no
It does not work this way on the 991.1
at least not in my experience- maybe someone knows how?
Old 01-13-2021, 10:42 PM
  #37
fluguy
fluguy's Avatar
The neutral/paddle thing freaked me out when I drove my first 991.1... thought I had broken something while on a test drive. Had a 2-3 second no-go at the light before I accidentally found the gears again. LOL
Old 01-14-2021, 01:15 AM
  #38
asellus
asellus's Avatar
Received 2,023 Likes on 1,256 Posts
Originally Posted by afk
no
Clutch kicking is a GT thing.
fluguy (01-14-2021)
Old 01-14-2021, 07:40 AM
  #39
Muu83
Muu83's Avatar
no
As others said above, seems to be a 'PDK-S' GT thing. I didn't even know carrera spec PDK went into neutral, so assumed it'd act the same as mine.
Old 01-14-2021, 08:02 AM
  #40
mtony
mtony's Avatar
Works on my 991.1 C2S.
Old 01-14-2021, 08:45 AM
  #41
B Russ
B Russ's Avatar
So it works on some cars... Dealer visit Saturday will hopefully provide answers to this, also going to ask about the Stop sale thing.
Old 01-14-2021, 08:58 AM
  #42
ICNU
ICNU's Avatar
This works the same on the 981 PDK cars as well. I have the Cobb PDK tune file which has an option to convert it to the GT car setup where pulling both paddles back and holding puts the car into neutral and then goes back into gear as soon as you let go, vs the factory "click on, click off". Its also reverses the center console shift direction to match the GT3. As stated above, there is no way to hurt the PDK in any way doing this at any time. The car will just go back into the appropriate gear for whatever you are doing at the time.
Old 01-14-2021, 09:29 AM
  #43
HooosierDaddy
HooosierDaddy's Avatar
982 is the same with APR tune adding kick feature.
as for the topic at hand, prior to tune it still had ability to enter neutral with both paddles activated
Old 01-14-2021, 10:50 AM
  #44
Ryan52589
Ryan52589's Avatar
For some reason I thought I remember reading somewhere hat his only works on cars equipped with sport chrono? Maybe not tho.
Old 01-14-2021, 12:54 PM
  #45
ICNU
ICNU's Avatar
I'm not sure on that either, but I do have the SC option on my 981 as a data point. I thought it was just a PDK thing, but that could be the explanation as to why some report being able to do it and others not.
Quick Reply: Neutral by paddles??
