Will these fit my car and does anyone have a pic of the oem ones? I have seen aftermarket tipsfrom fabspeed etc. but they cost more than these oem tips.
I didn't have exact one but I did have eBay tips on my old 991.1 C2S with PSE. not sure if you have PSE or not but fitment was good and looked much better than stock ones on mine.
No PSE. The ones I posted are oem dual tips. I think the C2S already has twin tips which look much better than the oval stock C2 tips on my car. The stock tips on my C2 look like they belong on a. Mercedes c-class or some Audi sedan.
I feel like these are no longer available. I’ve searched pretty hard for 991.1 PSE tips that aren’t $500
Assuming the box label is correct they are correct part number but my regular "oval" tips seem as though the pipe is in the center. These look like the pipe is offset.
OP you might want to hold off on buying those, I think they are for PSE.
To the best of my knowledge the non-PSE is a single inlet type that Y's out like these. I could have sworn I have seen cheaper versions of these in my search for reasonable PSE tips which are a dual inlet
Edit
I think something like this is what you need but of course do your own research... no idea why the link won't work... aliexpress gonna alliexpress....
997 tips will stick out a little too far on 991 C2.
thats the mistake i made. Got cheapper 997 tips from fleabay. They look ok but not great.
I also painted them black on the inside otherwise it shines like cats ***** after hes been leaking them for an hour.
lol yeah just thought i'd throw some funny in there.
so in the second pic it looks dark on the inside past the welds because i painted it with high temp spray-paint. otherwise inside looked almost as bright as outside.
i now realize i should have painted the outside Y pipe behind/between the tips as well.
