GT3 or GT3RS/GT2RS spoiler on C2S
#46
#47
That setup with the swan neck, the decklid has to be chopped up. Or he just used that swan neck with custom brackets only for track days which makes sense but doesn't use a decklid.
#48
I used the stock crossmember and was able to use the stock mounting point for one of the bolts that holds the actuator and another one that was previously unused for the 2nd one. I had to turn it just slightly to get it working. Originally I fabbed up a U shaped bracket that would utilize both mounting points and hold the actuator that way. Your cars appears to be a .1 so either or will work. 1 bolt is enough to hold the unit in place the way that its designed.
#49
@911. Sorry for bringing up an old post, but im curious as to how you did this? Could you please take pictures? I bought an OEM GT3 Decklid and i'm trying to figure out how it's going to work since the locking mechanism needs to be relocated further back. I was ready to buy an aftermarket fiberglass crossmember thing, but if i could use my stock one, that would be great.
#50
@97 Supra TT 991.1
#52
JuanK20 (01-04-2021)
#54
I found a company that sells a rep GT2RS deck lid setup that will allow you to purchase just the deck (since I want to do side winglets instead of the struts and upper spoiler).
Here's a link to the page for the deck. Apparently you can get it in Carbon Fiber, or Fiberglass Reinforced Plastic (FRP). I'm planning on having the whole thing painted anyway, so I'd be curious to hear the crowd's advice on which material to go with... or if I should even consider it... but since an OEM deck is $12k+, I figure aftermarket places like this are about my only option.
https://performancespeedshop.com/col...24786dfd&_ss=r
Have any of our members had any experience with these guys?
For reference, here's what I'm trying to do with my setup. Still need to find a source for the winglets. Debating on trying to 3D print them if I can't find something reasonable.
The following 2 users liked this post by DOG ON:
edirtaynine (01-05-2021),
PorscheC2S (04-19-2021)
#55
#56
I ran into some issues with even mounting the decklid and fitment after first shops attempt is like 90-95%. I plan on getting it to another shop but havent found anyone local to me that I trust, yet. Also there was a vendor that made those exact winglets, but they discontinued them. Likely due to no one ever buying them.
edirtaynine (01-06-2021)
#57
If you plan to paint the entire thing, fiberglass is ok but also keep in mind on how youll be supporting the deck lid. fiberglass is very heavy and the GT2/3 support hinges will break. Ask me how I know (have yet to figure this out outside of adding a traditional prod rod and drilling wholes/mounting it).
I've got a great indie shop that I have full confidence in. If they can't make it fit and work, I don't know that anyone could.
Does anyone have a better source for the side winglet blades other than Wicked Motorworks? Here's the link to theirs:
https://shop.wickedmotorworks.com/pr...runk-winglets/
I plan on binding them permanently to the deck lid, filling the seams, and then painting the whole thing so that it all looks like one single piece. If anyone has a source for the side winglets, or even the file/ability to 3D print them, it would be greatly appreciated.
#58
I am very interested in this setup
i currently have a techart type 2 wing but I would prefer the wingless GT2RS setup.
@911 how did you manage the deactivation of the active spoiler mechanism, pull the fuse, what about fault message? Techart provide a black box to splice into the loom under the drivers seat. I’m on my 3rd box as they keep failing and need to find a more permanent solution as I have lost faith in Techart.
Also when do you think a kit will be available from the vendor? I would be interested in exposed carbon fiber but would be concerned about the quality and if it would hold up over time, UV exposure. Do you know what weave they use and is intended to be exposed or painted?
#59
So, would you advise me to go with the Carbon Fiber version over the FRP? (Yes, I plan on painting the whole thing either way.)
If you get one, let me know how the original fitment is cause the china vendor I am working on has been slow to get the one I got tweaked. Originally, they wanted to offer something to the forum that fit 90%+ and with the help of a shop it could fit like OEM.
I dont have a time as of now. But I feel like most ebay brand offered units are all coming from one place. Mine I was able to get it to fit 80-85% to my liking myself. I then had a shop do the rest and they did an alright job. its now like 95% there. So I have been researching for a good place to take it to to re-do it. The weave they used is 2x2 but my unit was a fiberglass one with the scoops exposed. Any good shop can use proper clear coat on the exposed carbon so you dont need to worry about fading/UV issues.
#60
Active spoiler for me was coding + plug on the wing side (powers the fans/lights ect) needs to be swapped on only one pin. Pin 4 to 8. Coding only simply wont do it on the 991.2's. The black box scenario sounds like a headache. Are you not happy with your techkart wing? I think it looks great, and was my 2nd option if I couldnt do some sort of ducktail spoiler.
I would like to remove the box and find an alternative method. Can you detail out what is needed in terms of coding, also the pin 4 and pin 8 swap do you know the function of each pin.
Appreciate any guidance on how to get it done
Personally I prefer the GT2 RS duck tail setup
