Softronic Tune- 991.2 review
#61
I am not questioning @Softronic longevity, power gain, or drivability. There are plenty of positive remarks from folks here. It’s a great product no doubt. However, some tuners have the option to reduce or eliminate Sport mode burbles. We all know burbles are artificially programmed to the Sport mode only. Cars do not snap, crackle and pop in Normal and Sport +. Since @Softronic is on top of my list as well and I do not care for the artificial snap, crackle, and pop I simply asked the question and received conflicting responses. (I know…….. we had a trend about burbles few weeks back however we had no straight answer as well) to @smell911 s point above we do not have a clear “Yes” or “No” answer to - can @Softronic eliminate/minimize Sport mode burbles within their tune. I figured I pose the question directly to Scott @Softronic and hopefully receive a straight answer from the source?
Thanks!
Thanks!
#62
Thanks!![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Thanks!
I had the Softronic tune for 2 years. I had Scott remove the burbles in Sport mode in anticipation that I would get sport cats. He also removed the stop start. I never got the sport cats and do not have PSE. Before the tune I got small burbles in Sport mode which sounded good but did not want the increase in burble with future sport cats. Now my sport mode exhaust sounds like my sport+ exhaust---no burbles
Cur (06-29-2023)
#63
Premium Sponsor
Scott, @Softronic I would like to eliminate or minimize the Sport mode pops and burbles via Softronic tune. Is there an option Softronic tune which will eliminate or minimize the pops and burbles and still provide increase HP and torque? Also, is Dimsport software compatible with Mac computers.
Thanks!
Thanks!
Yes we can yet it may be limited depending on what and or if aftermarket exhaust is put on as they can be louder so you may notice some on deacceleration. You can only use a MAC if you run Bootcamp as that was for the intel based units. Generally it has to be some type of PC based laptop or desktop running Win7 or higher. What we often do is send a unit updated and the customer reads out the car and then send just the MyGenius without the cable etc back and I load the Tuned/Original file then ship the unit back ready to go. The unit fits in a USPS small flat rate box and cost $10 to send to me.
Best,
Scott
Softronic - Porsche Performance Software Tuning
Faster than a speeding bullet.
Cayman | Boxster | 911 | Cayenne
Like us on Facebook for updates and promos
24HRS Daytona Winners programmed by Softronic!
Porsche Interseries programmed along with teamed owned Tudor and World Challenge cars in an exclusive with Softronic.
Porsche PCA racing binary check by Softronic for compliance.
![](https://rennlist.com/forums/signaturepics/sigpic237323_2.gif)
#64
Hello,
Best,
Scott
Best,
Scott
#65
My 997.1 Turbo has a Softronic tune for I'm not sure how many years now. Close to 10? All I can say is that it is very quick and very safe. And that last part is most important. It transformed the car.
#66
Softronic doesn't add more pops unless asked for so im surprised you would get more....Or perhaps its my misunderstanding . We don't ad any for turbos as it will cause premature failure to them so perhaps you can email me more information to our contact...... We also will not do E85 or PDK tunes generally for the damage they can cause to a Porsche engine yet they are always changing.... Porsche has had 2 specific bulletins on E85 alone and not from tuning yet reactions with the motors comp. E85 is reactive to certain metal or aka corrosiv.
Best,
Scott.
Best,
Scott.
#67
Tier1Terrier (06-29-2023)
#69
On a side note, installed the P3 gauge a couple days ago. Took it out and wanted to see how much boost it would show on the display. It topped out at 18.3 psi according to the gauge before I let off. Not sure how much more boost its capable of but just wondering what other folks have been able to reach on their tune.
#70
#71
Need some help, I have a 2019 991.2 TTS, and I did the Softronic tune and noticed the vehicle is not acting right.
This video shows it better than what I could explain:
How can I remove the tune?
#72
https://youtu.be/ko3K6ZhqFM4
cbredesen (07-10-2023)
#74
Premium Sponsor
Hello,
Hello,
It looks like you have a PSM error Or a PDK error as it will do that with those errors in. as the car runs and if it was a flashing issue it would not at all. and I checked the file and its OK. They will also go into a limp mode from a TB that gets installed and not calibrated.
Best,
Scott
Hello,
Best,
Scott
orthobird (07-09-2023)
#75
I figured out the problem, i believe. during the tune process, I did the following other fun stuff:
1. removed the rear bumper
2. removed the rear spoiler
3. removed the air filter and its housing
4. removed the throttle body and the plenum and the y-pipe
5. removed the intercoolers
6. I did the tune, but never turned on the vehicle
7. i then replaced all 6 spark plugs
8. I changed the oil
9. I installed a new IPD plenum, then reattached the throttle body with the two connections and heard the clicks
10. i installed a new IPD Y-pipe
11. I installed brand new larger AWE intercoolers
12, installed new charge hoses with clamps that went from intercooler to the Y-pipe
13. then replaced the bumper and the spoiler.
SO more likely than not, I need to do a reset of the throttle body.
I just ordered this:
so hopefully this will allow me to clear all the codes and reset the throttle body (ETC) throttle control system
iCarsoft POR-II Porsche OBD-II Scanner Tool Multi-systems ABS SRS
