AC Mildew Smell
Old Sep 5, 2020 | 12:14 PM
  #31
shadialfar's Avatar
shadialfar
Originally Posted by nstar8
The dealer referred to cleaning out the system with Frigi fresh...See attachment of their service write up...
Did that at the very beginning, did not help!
Old Sep 5, 2020 | 12:56 PM
  #32
shadialfar's Avatar
shadialfar
would this work?
A/C Flush
Old Sep 6, 2020 | 11:19 AM
  #33
nstar8's Avatar
nstar8
Well crap...sorry to hear that man...I would demand my $$ back from Porsche since they didn't fix the car for the reason you brought it in...Good luck and hopefully you'll find a resolution.
I would also have them re-do the cleaning and frigi fresh...I can't believe you did not notice any improvement after that....
Old Sep 11, 2020 | 03:51 AM
  #34
shadialfar's Avatar
shadialfar
I have an update, I used yesterday a new AC Cleaner, I have a professional apply it in the vents, I can tel you for the first time since I bought the car, its smell free, I hope it remains, worth saying that the dealer refused to apply AC cleaner foam cans, I had to do it myself and it didn't work, I was doing something not thorough, yesterday I have it done by a professional for the first time, I will keep you posted!
Old Sep 11, 2020 | 09:11 PM
  #35
keithgreer's Avatar
keithgreer
I had this same issue recently and tried all of the things people have suggested in this thread. It turns out my evaporator had a leak in it and the smell was freon. Under warranty, they had to pull the dash and put in a new evaporator and now it no longer smells.
Old Sep 11, 2020 | 10:00 PM
  #36
TwinTurbo420's Avatar
TwinTurbo420
FWIW, I replaced both of my cabin Filters with anti-microbial filters & the smell is gone.
FCP Euro Hengst filters
Porsche Cabin Air Filter
- SKU: HEN-E3940LB
In Stock $34.49
- SKU: HEN-E3945LB
In Stock $10.49
Old Sep 13, 2020 | 05:54 AM
  #37
shadialfar's Avatar
shadialfar
- SKU: HEN-E3940LB
In Stock $34.49
- SKU: HEN-E3945LB
In Stock $10.49
Guys, do you recommend those?
Old Sep 13, 2020 | 12:29 PM
  #38
Porsche_nuts's Avatar
Porsche_nuts
Cabin filters should be changed every 2-3 years, so it can't hurt
Old Sep 15, 2020 | 05:33 PM
  #39
koala's Avatar
koala
I do the front trunk one every year- it gets really dirty, really fast!
Old Nov 7, 2020 | 09:19 AM
  #40
shadialfar's Avatar
shadialfar
unfortunately I still have the problem, is it only my car, should I sell it away and buy a new one?
Old Nov 7, 2020 | 09:51 AM
  #41
keithgreer's Avatar
keithgreer
My problem was a leaking evaporator which is behind the dash. It smells like mildew but it was refrigerant. Have someone do a leak and dye test to see. Fortunately mine was covered under warranty
Old Nov 7, 2020 | 03:11 PM
  #42
Norge911's Avatar
Norge911
So my wife’s Audi Q5 had same problem. Instead of using the heat trick, I parked it in driveway with full AC blast and windows down on a humid day for 30 minutes. Let the evaporator work overtime. Generated a huge puddle under car which is good because I knew the drains worked
anyway, seem to have cleaned it enough and no more smell.
Old May 17, 2022 | 01:57 PM
  #43
SamiRose's Avatar
SamiRose
Were you able to resolve?
I am having this problem with my 2020 Cayenne Turbo. Dealer has tried everything including changing evaporator coil.
No that is hot and humid the smell is back!
Old May 17, 2022 | 03:12 PM
  #44
koala's Avatar
koala
I tried the nextzett 96110515 Klima-Cleaner one time a few years ago in my 911 and it solved my odour issues. Beyond that, I still swear by changing the front trunk filter more regularly... this post is now my reminder that I haven't changed it this year.
It doesn't always work - I've tried the same stuff in my Kia Sedona a few times over the years and it doesn't really do anything for the odours in that vehicle... but my wife drives the Sedona most often, and she runs the AC 100% of the time.
The solution is really just to prevent this from happening in the first place - run the HVAC with the AC turned off in the last 2-3 minutes before your destination.
Our new GV80 has automatic air conditioning (not just auto climate, the A/C will turn off/on as needed to cool or dehumidify the vehicle sufficiently)... I think this will also prevent odour issues as the AC doesn't run nearly as often as a typical auto climate system where it is on 100% of the time.
Old Mar 21, 2024 | 04:02 AM
  #45
arcangely2k's Avatar
arcangely2k
How exactly did you apply the Klima Cleaner? Thx
