Programming multifunction display
Hi,
My PCM is dead. I am definitely going the aftermarket head unit option or radio delete with shelf. Sadly, before my pcm stopped completely working I did not know enough to change the settings so that “nav” “phone” and “audio” menus are removed from the multifunction display. Can this be accomplished with PIWIS instead? Thank you very much in advance!
bonus question: I can only find MOST adaptors for 997 amps. I would like to get an adaptor and do a little Bluetooth receiver with the radio delete shelf installed. Any of you ever done this?
Duncan
Duncan
Are you sure it's dead? There is an ongoing problem with the PCM if you have satellite radio. Porsche is working through the problem now, but haven't found a fix yet. Also it would help if you included the year of your car. There were changes and updates through the years.
The Ox (05-27-2020)
I would try it but when I picked up my car from the dealer it has even less functionality than before. Now all I get is the emergency boot up page because they attempted to do a software update. Apparently that update didn’t work. At least before I would have 2 minutes of full functionality on the pcm before it went though it’s crazy auto reboot process. Dealer ordered me a new pcm but the part has been on backorder for weeks. I don’t think I’m going to replace it. 4600$ buys a lot of tires and brakes.
I would check into that thread before deleting the PCM. To swap the hard drive for a SSD which is way more solid and stable to heat and road bumps just makes sense to me:
https://rennlist.com/forums/audio-an...ve-to-ssd.html
or here
https://www.planet-9.com/threads/pcm...to-ssd.243528/
or here
Class5Kayaker (05-28-2020)
Hi,
Duncan
Duncan
The PCM hard drive also died on my .1. I did the SSD clone/swap and it worked great, but I ended up replacing it with an aftermarket head unit anyway so I could have wireless carplay/android auto. I can still enable/disable the multi-function menus via the settings screen in the multi-function display. For the MOST adapter, I used the MOST-H.U.R.31 from Navtv to adapt the aftermarket radio. I would think you could also use it with a bluetooth adapter. the Navtv adapter uses line-level RCAs to connect to the aftermarket stereo.
I got mine from him and it worked great. I didn't need to have anything coded, either, it just all worked. I go back and forth on whether I like the PCM or aftermarket head unit better...the UIs on aftermarket head units are pretty terrible, but at least I can use Android Auto wireless. The aftermarket unit just looks sort of out of place to me in the 911.
