Heat Shield Recall
Old May 21, 2020 | 12:10 PM
  #91
pfan's Avatar
pfan
Originally Posted by wilsonaudio
I woke up this morning to take my 2014 C2 911 991 for heat shield recall. On my drive in the PCM started shutting off every 2 mins. Talked with the dealer when I arrived. Said it would need a new PCM to fix the problem if it wasn't just an easy software update. Just a coincidence? Dealership had another 991 in with the same issue.
Yours is the third or fourth occurrence within the past few days. Can these hard drives be coincidentally failing on their own, or could it possibly be due to a Sirius/XM software issue. (I haven't had my car in for any work lately, so in my case it isn't a possible dealer software reprogramming issue). Maybe we should open a new thread dealing with PCM failures.
Old May 21, 2020 | 01:30 PM
  #92
shammerman's Avatar
shammerman
There is now a (new) PCM Issue thread - https://rennlist.com/forums/991/1195...os-update.html
Old May 21, 2020 | 03:15 PM
  #93
Southbranch's Avatar
Southbranch
My dealer just told me that Porsche attributes the PCM reboot loop problem to a change made by Sirius XM. The correction is some kind of PCM "reset", which they can execute for me in their driveway without an appointment. I do not have details yet, but apparently my settings/preferences will be lost during the process. They've had a rash of calls from customers about this.
Old May 21, 2020 | 04:51 PM
  #94
sampelligrino's Avatar
sampelligrino
Originally Posted by Pavegeno928
Cool! What number is yours? I checked the VIN tool when I heard about the heat shield campaign and it returned "no open recalls." Guess the key is that it is not a recall, but a campaign which probably means, whenever you see the car in the dealership next, fix it. That's one of the reasons I go to the dealer. I have a good one here and they have never gouged me.
I have #672, but interestingly my dealer said my 50th is only eligible for the WLA4 Installed Heat Shield campaign. They didn't mention anything about "WLC8 Installed Tank Leakage Module" so I'll need to follow up
Old May 22, 2020 | 04:25 AM
  #95
Schorsch's Avatar
Schorsch
Do you have a US-Model 991? I think I can remember hearing that only US models have the Tank Leakage Modul due to emission regulations and the European models don't have the modul installed. Can anybody confirm this?
Old May 22, 2020 | 08:29 AM
  #96
Pavegeno928's Avatar
Pavegeno928
This is interesting. When I had my US spec 991.1 in Germany I had a check engine light shortly after I brought the car into the country which the Stuttgart dealer took three days to figure out. It was a sensor in the fuel tank they replaced for emissions. It took them a few days because the RoW cars didn't have this sensor so none of the mechanics had seen this before. Could be the same thing.
Old May 22, 2020 | 11:40 PM
  #97
Bemo's Avatar
Bemo
Originally Posted by LexVan
OK, quick question. A few of you have already noted this Air Filter. What the heck filter is this, and why is it a $132 part at places like Sunset?:
https://www.sunsetporscheparts.com/o...er-00004321007
This does not sound like the simple inexpensive ($20-ish) accordion style pre-filter in the frunk, nor the active charcoal filter ($60-ish) in the cabin under the glove box. So what is it??
My SA confirmed that the recall required one of the air filters to be changed: https://www.suncoastparts.com/product/PK991AFK.html
Unfortunately, they didn't ask if I would like to pay to have the other one replaced.
For those about to get the work done and need new air filters, this is a great opportunity to pay for the part only and not the labor.
Old May 23, 2020 | 02:40 PM
  #98
FlyJacket's Avatar
FlyJacket
My SA confirmed the "workshop" issues but said the rear bumper does not need to be removed to replace the heat shield so there are no savings to be had on any other service work. Not sure I believe him after seeing all the pictures above. 2012 991.1S.
Old May 23, 2020 | 04:34 PM
  #99
GSIRM3's Avatar
GSIRM3
For people saying you checked your VIN for recalls and found nothing, that's because these two items are service campaigns by Porsche and not recalls.
https://www.carfax.com/blog/tsb-vs-recall
Old May 23, 2020 | 05:00 PM
  #100
0luke1's Avatar
0luke1
From: South Florida and Jersey shore (Monmouth County,)
Mine’s going in on Tuesday, they’re also going to replace the CRM 114 discriminator.
Old May 23, 2020 | 06:59 PM
  #101
Southbranch
I had the heat shield retrofit campaign done recently and was told that the taillights were removed for access, but not the rear bumper. However, my GTS has a ducktail spoiler that is easily removed, so it might be different than cars with the normal spoiler.
Old May 24, 2020 | 01:55 AM
  #102
Larson E. Rapp's Avatar
Larson E. Rapp
I'd suggest having them swap out the AE-35 unit while they're in there. They all seem to fail eventually, might as well take advantage of the free labor.
Old May 24, 2020 | 08:47 AM
  #103
Pavegeno928
Be sure they enter the code "OPE" into the PIWIS or the CRM won't receive at all. Ask me how I know.
Old Jun 10, 2020 | 01:02 PM
  #104
SConn's Avatar
SConn
Has anyone else had the heat shield recall done lately? I'm just wondering if anyone else's shop didn't have to remove the rear bumper to do it?
I just scheduled mine for July and was told the rear bumper needs to come off. I'd prefer it if that wasn't the case. Or maybe in the end it's better to prevent even more possible damage to the bumper?
Unfortunately the dealer threw in a "they are getting better at it." Ugh...
Old Jun 10, 2020 | 01:13 PM
  #105
shammerman's Avatar
shammerman
Why do you worry about the rear bumper coming off? It has to come off for air filter changes as well so it's going to happen multiple times in the life of your car.
