991.2 Spark Plug Replacement Instructions.... FINALLY!
Old Feb 14, 2020 | 08:42 PM
LargePuppy's Avatar
LargePuppy
Default 991.2 Spark Plug Replacement Instructions.... FINALLY!
The following PDFs should guide you through replacing your spark plugs!
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 14, 2020 | 08:44 PM
LargePuppy's Avatar
LargePuppy
And these might be useful when doing the plugs
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 14, 2020 | 09:03 PM
Omega4's Avatar
Omega4
You, my friend, are awesome! Very much appreciated! I’ll probably take a crack at it in next couple weeks.
Old Feb 14, 2020 | 10:08 PM
bkrantz's Avatar
bkrantz
Thanks!!!!
Old Feb 14, 2020 | 10:14 PM
Ryan52589's Avatar
Ryan52589
Thank you
Old Feb 14, 2020 | 10:27 PM
BOPE's Avatar
BOPE
Thank you there LargePuppy!
Jason
Old Feb 15, 2020 | 10:11 AM
Carlo_Carrera's Avatar
Carlo_Carrera
Thank you.
Old Feb 15, 2020 | 10:23 AM
Carlo_Carrera
Am I reading this right in the heat shield removal pdf? It appears the turbocharger must be removed in order to remove the lower heat shield, but to do the plugs only the upper heat shield needs to come off?
Preliminary work for heat shield (lower part)Information
This preliminary work is only relevant for removing the heat shield (lower part).
1. Remove turbocharger. → 213019 Removing and installing turbocharger - section on "Removing"
File Type: pdf
Old Feb 15, 2020 | 11:11 AM
Jack F's Avatar
Jack F
Thank you for getting this information!
Old Feb 15, 2020 | 11:12 AM
Jack F's Avatar
Jack F
Let us know how it goes.
Old Feb 15, 2020 | 02:23 PM
Omega4's Avatar
Omega4
Looking at the third diagram, it looks as if you can access the ignition coils without having to remove the turbo and thus the lower heat shield...at least I hope so...
Old Feb 15, 2020 | 06:25 PM
Ryan52589's Avatar
Ryan52589
I’ve had the upper heat shield off and the intake tube, seems impossible without removing that lower heat shield.
but I hope someone proves me wrong!
Old Feb 17, 2020 | 11:29 AM
LargePuppy's Avatar
LargePuppy
I've added instructions for the turbochargers in Post #2
Old Feb 17, 2020 | 04:11 PM
Omega4's Avatar
Omega4
Dang, me too! I’m not fooling with removing the turbos.
Old Feb 17, 2020 | 08:44 PM
Kelsey's Avatar
Kelsey
Thank you very much.
